Steering Vibration after 120km/h
mick87
576
112
1,543
hi, i hv recently changed from my standard 15inch rims to 17inch with center cone, before this driving at high speed without any steering vibration. After changing, there's minor vibration at the speed after 120km/h..should I go for another balancing or any other solution for this.
boi
368
26
check the balancing 1st...normally if u change rim/tyre at famous shop they will do balancing cin cai only...
mick87
576
112
1,543
ok will do, will start with balancing and allignment first.
EvolutionV7
232
7
Johor Bahru
zerotohundred.com
I face the same problem like you too. but mine problem comes after few months i change my rim from 17 to 16inch.
Not only steering vibrate...even gas & brek pedal also vibrate...
I have go for aligment and balancing at separate shop...still same.
I suspect might be the engine mounting (should be the 2 on crossmember) kong alreadi as i m driving auto transmission car. When i engage the gear to D and press brake..the whole car vibrate quite badly..
Any other possibility?
mick87
576
112
1,543
i dont think mine will have this prob, cos my car is only over 1 year old. Why do u change from 17 to 16?
boi
368
26
i think thats is the reason otherwise if u say during braking only got shake then that was related to rotor...
if u said pedal involve that one sure mounting...
EvolutionV7
232
7
Johor Bahru
zerotohundred.com
Tires getting expensive..Furthermore..found japan rim at 16inch...
17inch taiwan rim a bit too heavy for my auto car.
nothing wrong with the braking...but i dont know whether mounting will causes steering vibrate at 100km/h
EvolutionV7
232
7
Johor Bahru
zerotohundred.com
Finally found the problem last Saturday.
Send to workshop 1, they say no problem with mounting and driveshaft... Ask me to go another shop for aligment / balancing / Rotate tires.
Send to tyres shop 2, when he open up my wheel, they found out that the centre cone was too small for my current rim. Changes 4 aluminium cones problem solved.
Damage: RM100 - 4cones + RM20 - Balancing + RM25 - Alignment.
Result: Satisfied :biggrin:
richnet
21
1,503
Penang/PJ/KL
yea, i was about to say it's the center cone that it giving you vibration.
actually, you can just ignore the center cone, in order you screw your rims real tight using the compressor gun... but if can put cone, it's better le...
to have better performance, do on-wheel alignments...
mick87
576
112
1,543
mine also settled about a month ago, they did on wheel balancing...rectify until the problem solved., now driving high speed 140-150 dun have much noticeable vibration
AR123
bro mind to share which workshop did u visit ?
I am having the same problems and would like to check it out.
megancheung
Apr 11, 2012
11
503
On wheeling balancing did not help? It should, because when on wheel and spinning you can see whether the wheels are centralized or not. High speed unbalance is normally due to not centralized of the wheel to the hub.
Well today after a bit of aggressive driving, my radiator gave up on me after 12 years. On the highway, engine was shut down and i notice the temperature was above normal. My friend was driving my car and he managed to control the car well on a corner and slowly breaking with the hand brake until the side of the road, was worried about the engine, so i checked the engine oil after some time and was happy it looks normal and no MILO colour.. no white smoke at the exhaust as well..
took some...
