Opinions of GAB HA series height adjustable suspension
apeng
533
www.kcarlife.com
from my opinion...find GAB fr Japan....u will satisfy....
GAB which available here im not sure....could be recond set......
Mitevo7
1,456
179
haha guys that was imformative to me , how does the kg rate of the spring affect my ride quality ? Notice u guys been mentioning 4kg rear , 6kg front and etc ... That differs the stiffness of the spring ??
arrowhead
4,621
152
5,163
Damansara/PJ
yeah. it means how stiff the springs are. as i was told, 6kg front 4kg rear is for comfort driving rather than performance (track use perhaps?). well im not all too satisfied with my 6kg front 4kg rear... too soft for me.. i need something harder... i wanna feel the BUMPS on the ROADS..
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
why jin?they look the same is it?
yup, almost the same... even the color oso 100% same...
btw, if the SS is from the same factory, then that set of damper kit is damn good 1 loo....
starscream
147
what is the piston diameter of the SS series compare to others? i got to know the bigger diameter allows better damping. is it true?
GT_AUTO
3,503
71
K.Trg
www.facebook.com
bigger piston can dissipate heat better too.bigger piston=better damping,it's true.
reason,forgot....hehehe...try google it up star scream.i've read the article before.
there a good reason why all adj sus manufacturer racing to make their piston
bigger.the biggest that i've heard of if i'm not mistaken is a round 48-52mm.
don't shoot me if i'm wrong.tend to forget a lot of car tech lately.hehehe.....:rofl:
I'm driving Daihutsu Mira L5 and i suspect that my turbine got leaking. The original B.O.V blow out small amount of oil that should not be normal right. So what should I do, should I just replace it a recond turbine (kedai potong) or send it to service. Which work shop do turbine service, how much does it cost?
