namzy:erm...drift club for GT4....kekeke...in DCM got LFS team, in ZTH if got GT4 club quite good also...kekekeke :lol:
hehehe,Kaido Battle 2 ah....quite good but i think inside the game when I drift FF cars even nicer then FR or MR....but usually in Kaido Battle 2 i will use the Greddy MRS to drift....compact and easy to control...kekekeke :lol:
Yeah, not only in Kaido Battle 2 but also in other games...even in GT4 also, lower HP cars are even better to control...imagine you are engaging some tight corners,for example those tight corners at Trial Mountain after the first tunnel.....imagine driving a 400 HP ER34.....man you need to use handbrake a lot of times to minimize the speed around the corner and summore make the car continue to slide....where else with cars like a S13 '88(with a CA18DET engine) or a Levin/Trueno, you just press down the gas all the way, the easiest way is to just do a power-over technique over it....of course i am not saying high HP cars not good.....even at courses like Mini Autumn Ring and Infineon Stock Car Track, you need to have a higher HP car so that you can drift corners which are at uphill
farique: B4 i went and got my PS2 set, David(Metalzone) and Stanley approached me to play it...later my classmate Boon Leng also told me the same thing. But that time i have only the budget to do one of the things: either buy a PS2 to play or use the same money to upgrade my PC(which is 5 years old)....so I opted PS2.....of course if got enuff money i dun mind playing LFS too....kekeke....just look at David's case....in real life only drift with his FF Iswara, but then in LFS can drift FR...later from LFS can get the skill to drift a real FR car, summore the FR car dun have LSD....huiyooh....must be good the game....kekekeke :lol:
Fai: Are you refering to the videos that I posted? if you are refering to those crap videos that I did, I have tried to straightened the car after drifting a corner but many times i find myself spining if i quickly make the car straight, so my solution is to chouko-dori a bit until i can more or less sure that it is time suitable for me make the car straight.....this may sound crazy but that is usually what i do.....
Regarding the rubberband trick thingy...I have tried but for only a period of time because later I found out that my analog stick will start to corrode....meaning that there will be plastic powder starting to come out of the analog stick.....then i decided to take out the rubberband....what to do?it is my one and only precious white controller(ori PS2,not PSOne)....
To upload a video, you can use
www.putfile.com's services. It is free and quite okay(aiyah, free one...what can you expect?)kekekeke :lol:
