does water injectors help in cooling?
scoupe
1,087
37
shah alam
i was wondering all this turbo and supercharge cars sure got temp problem during traffic jam rite? does spraying water on the intercoler help alot? if so roughly how much is it for a water injector kit ?
ant_tey
59
3,008
Johor Bahru
Not external but internal YES n cos around 2K.
BLaCkHoWLiNG
'(^^)|Most Awesome Member
8,650
1,349
www.autojunctions.com
temp problems during traffic jam will only be solved by installing bigger, faster fans.. and make sure infront, there's no obstacle for cool air to be sucked in by these fans... if u're running a crank driven fan.. make sure the fan clutch is alrite.. else change / service it... water injection system will give u a cooler intake temp.. but will not help u with 'overheating' problems... go to www.aquamist.co.uk.. check it out...
Lord_darkslide
451
ya i've been thinking about "intercooler water spray" oso... hmmm mebbe can just d.i.y ....
Joeker
Walking Dead
3,580
62
Jinjang
I think there are 2 common tupes of water injection.
For combustion and intercooling.
Water injection into the combustion helps to cool down intake temp and increase power (H20 increases compression therefore precice regulation of the quantity of H20 is vital to prevent blown motors)
The use of Water injection into combustion was revolutionized by the German Luffwaffe during WW2 when German Engineers used water injection on ME-109 fighter planes.
Water injection onto the intercooler (which currently is a standard feature on EVOs and Scoobies) increases the intercooling efficiency by radiating the heat off the fins via water evaporation.
dear sifuses,
my problem is, the starter wont stop working even when the engine already starts, even more surprisingly it's still working when I turned off the key. thought it was the relay problem, changed wit my horn relay still problem persist, spent a bit more & use a new 1 just making sure & stil same problem, it even burnt my jumper coz starter wont stop, luckily nothing severe happened, if the other car engine wasn't running bet it'll drain the batt 2. any thoughts @ this...
