D.I.Y Oil Catch Tank RM6
edwin_lcw
1,242
Setapak
wah ..... like dat also can ? what called it when u go into a hardware shop to find ?
n_chun21
352
sri damansara
not is ok i already ask the modification shop they said will ok.. if u don't want like this got other cheap method.. u buy a long hose connect to the engine there until to the bottom of the car so got a little bit oil will go to the ground then the air hose use a nut screw it.. is a same method no need u away change ur oil catch tank.. hope u all know wat i said....
datsun
40
3,008
haha.. still got budget mod Rm2 for the long hose but "n chun21" ur idea is great
mengz
605
guys, i have another suggestion. what i use is the erm petrol filter for proton saga's/iswara. its like a plastic container with 2 mouths. its like rm8 from sparepart shop. inside the container got filter summore :) when the container full edi, just change it lor. ehhehe
n_chun21
352
sri damansara
hehhe.. i just saw this long hose connect to the bottom of the car from the modification shop they said no need waste money just like tat is ok liau... mengz ur rm8 is the oil is full then need to threw it or not?
edwin_lcw
1,242
Setapak
using the iswara petrol filter is a version of KHGUAN ..... sorry ..... he finished oledi .... sucessful DIY
n_chun21
352
sri damansara
yup i know but his petrol filter finished the oil catch tank is more than rm20 la borther ... me not more than rm10 if just used a hose not more than rm5.. so u think who is cheaper.... and look it who is more look like oil catch tank
edwin_lcw
1,242
Setapak
n_chun ..... not spoiling your DIY or making u down .... but did u heard of drexx say about the perfume container towards the petrol substance ? ..... n how is your OCT going ..... i wish i could do one like yours ..... your look like a OCT but drexx said the container is not good in holding the oil ...... can share your eyes to us ?
n_chun21
352
sri damansara
ok now i already install to my friends car wira special edition more than 1 week ... in good conditional not kemet and other thing and also got oil inside... i know ur mean so inside the OCT i got put some span at the bottom and some metal grill inside make it cold so this OCT my friends said is ok at all his car always drive to shah alam and traffic jam go back to setapak so until now is good conditional...
the inlet u go to buy a metal hose same size as ur air hose metal is ok liau
-sky-
196
5
nice DIY.
really keen on trying to do it.. thanks for the idea.
:driver:
sebastianloeb
253
Me also use the used petrol filter as my OCT. But need to remove the filter inside & clean it first. I then reattached the cap using hot glue.
My kancil have l6 engine with rhf4 turbo and emanage blue. But the fueling system(fuel pump, no fuel regulator and injector ) is all stock. The question is, after i add fuel regulator + upgrade my injector, is it a mandatory for me to setting my emanage for the new fueling system upgrade? Does it will effect and damage my engine if i setting my emanage later if i got money?
