Anti-lock Braking System (ABS)..
D7zul
2,697
848
Shah Alam
Good day to all ZTHians,
I almost had an accident a few days ago with my KE70.. but thankfully there're no cars around me.. :biggrin:
and i believe KE70 doesn't have any ABS system, right? if there is, i would love to install it :wink:
anyhow, actually i wanna ask about my AE101 Levin.. my levin is originally an auto n without ABS..
after putting some performance parts.. i think it's wise to upgrade the stopping power as well..
I would like to put ABS on my levin.. does any1 know/done installation of the ABS for AE101 Levin?
Tq
ixeo
4,788
3,080
KL, Malaysia
IF AE101 has an ABS model, then I believe it is possible. Because people have managed to install Myvi ABS from Toyota Passo into Myvi's that did not have ABS.
D7zul
2,697
848
Shah Alam
Not sure about ae101.. But ae111 hv ABS..
What part should i buy n install?
punk
360
76
528
Negeri Sembilan
Basically at the bottom parts, u need the stuff llike in picture:
1. Round circle - sensor
2. Arrow - Sensor fan thing:confused:
Other i not sure.
U sure u wan upgrade? Going to be expensive.:driver:
some myvi user claim their abs got defect so accident happen.
He claim that the fan thing attach to the hub not balance, so he can't break properly even drive at low speed.:confused:
D7zul
2,697
848
Shah Alam
Other i not sure.
Wow.. Seriously?
I used to own a BT engine in my ex ae92.. But I've never seen that sensor n fan b4
N my BT hv ABS
I think different model different system
punk
360
76
528
Negeri Sembilan
Wow.. Seriously?
N my BT hv ABS
i also not sure.
Thats what the guy wrote.
I jus attach the pic to share some info some part of ABS that i know.:listen:
Actually the "fan" name is not actually a fan.
Hope u dont get it wrong because i also dont know what it is called.:biggrin:
I think the fan thing is to let the sensor to pick up the signal as 101010101 in digital.
bera
822
229
hi dzul long time no see aa...
try to find complete parts...from brake hardware,sensors and CPU box thingy...the problem is most chop shop cut the sensor at the disk brake assembly...and cpu box thingy goes together with the half cut...abs wont work if you missing either one...
D7zul
2,697
848
Shah Alam
Hi bera, how r u lately? Ur car ok ke?
That's what I'm afraid of... Need d whole halfcut to get ABS..
Coz i can't find any1 selling complete set of ABS
bera
822
229
i'm fine...just busy with kids...car just like it use to be...with its natural patina...
parts sure can find...maybe need to order first in advance...
your main thing is this...similar to this...
http://www.zerotohundred.com/newfor...4787-ae111-toyota-corolla-abs-brake-pump.html
brake line maybe need rework...originally this thing is located near driver side head lamp...and then come the sensors...i never seen one first hand...so i dont know what they looked like or how they are attached together...
D7zul
2,697
848
Shah Alam
the servo also a bit different from mine..
coz i juz saw a fren's ABS servo with extra hose/wire coming out of it :hmmmm:
haha.. i think it's safer to buy a halfcut & take all it's braking system than to buy parts 1 by 1 :biggrin:
Tq
Your accident was in the wet or dry? If in the wet, drive slower loh! If in the dry, to me without ABS is better, more responsive.....:driver:
bera
822
229
also heard some people say...abs takes the feel out of braking...what ever that means :confused:
for the hassle of getting the abs to work...better spend on better pads,tires or upgrade caliper/rotor...
D7zul
2,697
848
Shah Alam
Actually it's wet that time.. At an empty road.. Entering a corner to drift but hit an invisible pool of water.. Loose control sliding 4 a few metres n stop in d middle of d road.. If got abs, can do correction n drift with style.. Haha..
For my Levin is just for safety purposes :biggrin:
d7zul, bera has pointed out the most important thing about ABS self installation. Half cut shops destroy the whole setup before you get to buy it. If you're really serious on getting one better you find out which one will fit your wheel hub first, then buy everything new. Otherwise go master the secret art of ABS.. Aku Brake Sendiri. Ie- threshold braking
:biggrin:
D7zul
2,697
848
Shah Alam
ABS saved my life once.. N i want it to save my life again n again n again :biggrin:
Looks like i need to get a halfcut to install it..
I think I'll get myself a BZR halfcut.. N take its ABS n superstrut
The rest I'll sell :biggrin:
---------- Post added at 10:36 AM ---------- 6 hour anti-bump limit - Previous post was at 09:11 AM ----------
threshold braking can also be done with ABS..
So, i hv a few choices in case of emergency :wink:
Based on the Lotus Exige. Powered by a twin-turbo V8 with 1,200hp and 1,537Nm of torque, weighs in at only 1,220kg, and that effectively makes it more powerful than a Veyron. It's able to accelerate to 100km/h in 2.4-seconds, before a hitting a top speed of 440km/h. That my friends, is the Hennessey Venom GT, a true hypercar down to the very last nut...
