Prevention Of Car Theft
gavinchong
89
4
1,508
I hope all members know what am i talking about because it is the security that we need as a prevention of losing our cars!!!
Okay.. Here are the ways of it
1)steering lock
2)gear box lock
3)brake lock
4)clutch lock
5)Front bonet lock (Prevention of theif opening front bonet + kills alarm)
6)Armed swtich (Manual Immobilizer On/Off by switch. Only applies when switch is ON, the car's ignition is OFF/engine dead (manually) and then when you turn ignition ON to start engine, NO WAY to start unless switch is OFF)
7)Movement sensor (Alarm triggers when somebody breaks your glass/Motion is detected)
8)Shock sensor (Alarm triggers when car is shaking,moving,lifted,towed)
9)Tinted unbreakable glass (4mm/6mm/8mm) (harder to break if its being "hit" by hard stuff, i.e helmet,hammer)
10)Immobilizer (3 types. Card/Key/Chip. For Hi-Jacking usage. Cuts low voltage ignition circuit, fuel pump circuit, low current starter motor circuit from key switch to relay)
11)gps tracker (Seperates from alarm. Able to Track, Immobilize with phone/operator)
12)gps alarm (Comes with alarm. Track,Immobilize,Check car status with phone/operator.All in 1)
13)gsm alarm (Immobilize, Check car status within phone stations with phone/operator)
This is the method of thieves stealing your car:-
(1)Theif No.1 will attempt to open your door + front bonet
Theif No.2 will standby in front to open ur front bonet and kill your alarm
Theif No.1 will attempt to break all your locks and drive your car away
Note: Apply front bonet lock + Immobilizer + sensors + other locks
(2)Bring tow car and tows your car away
Note: Apply seperate gps module or gps alarm for tracking purpose
Scary eh...???:bawling:
In this situation, if the above Ive mention and you've got it
Theres no reason we are scared of our cars being attacked :proud:
If there are any questions, pls do not hesitate to share with our lovely members~~
I've got friends who deal with these stuffs too :)
gavinchong
89
4
1,508
Where to get those gps tracker,gps alarm,gsm alarm??how much??more features??:hmmmm:
High End accessory shops only has it
GPS tracker should be around RM22XX~~ (Track ur speed, cars location, immobilize)
GPS/GSM alarm should be around RM3XXX~~ (Check doors open/locked, immobilize, status, car locate for gps using coordinate, for gsm using phone station within few hundred meters of range)
kelvins3281
1,014
Wow...agk kaw la the price...but gud for secure...:driver:
gavinchong
89
4
1,508
good things no cheap..
cheap things where got good?
Especially serious ICE users, they will surely consider bout this cauz their full set of ICE costs way more than that
jameswwt
1,127
78
1,648
Put a Vernomious Cobra pet in yr ride whenever u left yr car...Sure hak kau sie or ngau kau sie the theive...hehe
gavinchong
89
4
1,508
cannot lar... Malaysia's weather too hot.. Cobra sure die inside ur car.. lol
ExODus
463
On my way on finding a gear lock...
ExODus
463
Dear brother, locks are the easiet break up thinggy for thiefs.. :)
Why not getting an immobilizer as the price is not much difference?
I have those... Just wanna be sure... so i'm thinking of installing all the less pricey stuffs first... :idea:
gavinchong
89
4
1,508
Then you should add some "visible" locks first.
Lets say (thief must attack with only 2 choices):-
1)you have gear box lock
2)my car has a a steering lock (which is visible)
Sure the thief attack you first la..
ExODus
463
I'm intend to do so... thanks for the heads up...
recently realized my car has been making squeking noises and after
inspection i found that it comes from the seatbelt harness..it squeks
everytime i move it,very very irritating and am wondering if i theres
anywhere i can rectify this..
any help is greatly appreciatted
