Just a quick question, do i need to change my rocker arm if im to install the jasma camshaft?
nk guna piston 1.6 4g92??? 75.5 nk korek smp 81mm?? msuk stroker kit waja 4g18 :)
nak gune piston 4g18 boleh ke bro? atau ade ke stroker kit 4g18?
Bro iszo, so got the pic already?
Btw can i simply use the 1.6 piston (korek abit) with stock ecu running it? alang2 since i open the engine head.
is this waja crankshaft and pistons easily available bro? and do i need to change my management? or is the stock one should be enough for now?
Bro, seems like alot to do if rebore. Might just save my money to supercharge next time. Alang2 use ecu..
So far, ive managed to get the 421 extractor n 2.0" piping (just to prepare just in case...), camshaft n cam pulley, aluminium radiator (for the looks), diy cold air intake, bosch 4 spark plug, properly check everything...
Next is to source the crankpulley as mentioned by bro iszo...
N tbh ive spent well, below my expected budget (lets just say all these items equals to my ex yaris trd short shifter n pulley only, from japan of coz.)
With all these, can I expect any gain? Can play w stock vios? Aha I know for sure weight of satria n vios almost the same.
the internals have to be strengthen as well if you plan to supercharge the engine in the future.
Tq bro. but for now, i want to see the progress of the hp gain. if it can play with vios or those 1.5 engine, I am going to slow down for a bit and will continue next year for supercharging and maybe a standalone, or maybe i dont have to do it if i am satisfied with the gain so far
Bro, stroke + oversize pistons + cams, PNP, balanced and a 3-speed auto wira aeroback and keepup with a Vios easily. Only problem is top speed, 3-speed auto gear ratio not long enough. Too long and you lose pickup.
Imagine what a satria manual can do with a lighter body!
I want a 1.8 gearbox. My current 1.5 manual ratios are too short. But if I can find the budget, I wanna change the final gear ratio.
Btw, I think cost wise stroke/oversize/pnp/lighten/balance vs supercharge, I think price wise they are very similar. But the SC will give you bigger gains I think. But imagine if you had the stroke and all done before supercharging.
POWAAAAAAAAAAAAAAHHH
Similar threads | |
