Kembara dvvt in dire need of help..
fazidk
3,163
413
5,183
Hi guys...like d topic says d car is in need of help..u c it's leaking a bit of engine oil (it's just been thru a major overhaul in s'ban)..from Wat I can see is that it's due to d cover x 'gummed' properly (apparently there's x gasket for this therefore use only sealant)..sounds ez enuff rite??thats Wat I thought..d problem is I x get d crank pulley off!!manually wiz hammer..FAIL..air gun..FAIL..it's like d pomen who overhauled d car put in loads n loads of glue..:(
Honestly I've sent to pomen n he gave up..stil had to pay for labour tho :(
Anybody????heeeeelllpppp
punk
360
76
528
Negeri Sembilan
Crankshaft oil seal leaking?
u diy opening crank pulley bolt?
The belt might slip u know, if u dont know what u r doing.:biggrin:
fazidk
3,163
413
5,183
It's x d oil seal (from what I can see)..x la I sent it to workshop they x open it even wiz air gun..I x know how to explain :hmmmm:it but it's like trying to remove valve head cover but in this case have to remove d pulleys 1st..
punk
360
76
528
Negeri Sembilan
U mean want to take off the timing belt cover rite, but before that need to take off the crank pulley off.
kembara is running on timing belt?
Better don't do it, if u never diy timing belt before. u might slip one tooth on the timing belt if u turn wrong direction.
fazidk
3,163
413
5,183
Yup bro I think that's d cover:)..using timing chain tho x belt..x planning to DIY (unless got sifu to help la)..
ecovent is kind of a device, when ur car is very hot, reach to 40c, it will open to let the hot air blow out....so the car will not be that hot
or so i heard la...
but i havent come across this device for cars...
anyone can share? if it's good, then i'll install it as well since the weather now is crazy!!
