What adjustable absorbers satria neo using?
calvinchan94
Aug 15, 2013
10
Hello ZTH sifus, I would like to ask whether wira/satria rear adjustable coilovers compatible with satria neo? I heard that they say they are different . shorter/longer is that true? I had the front one since i bought from halfcut . Thanks for replying ! :driver::driver::driver::confused::confused::confused:
front is same...but rear the neo need longer struts..around 2-3inches if i remember correctly
Thanks ... ^pomen_GTR^ . Would like know even with body shift also cannot not be done on the satria Neo?
if bodyshift i think its possible... but better u compare side by side first before decide...
boyzone
2,669
Body shift can to support, but u will not able to shift up more than 2 fingers gap ... .:listen:
actually for rear is same as wira/ satria mount..just the body struts were longer a few inches
Hey Guys,
I planning to do a open pod filter in my iswara (4G13 carburetor). The iswara is built with a drop in filter. So my question is that
a) what parts are require to fix an open pod filter
b) do i need a heatshield if i'm planning to make a cold air intake
c) where is the most reliable place in KL
