What adjustable absorbers satria neo using?
calvinchan94
Aug 15, 2013
10
Hello ZTH sifus, I would like to ask whether wira/satria rear adjustable coilovers compatible with satria neo? I heard that they say they are different . shorter/longer is that true? I had the front one since i bought from halfcut . Thanks for replying ! :driver::driver::driver::confused::confused::confused:
front is same...but rear the neo need longer struts..around 2-3inches if i remember correctly
Thanks ... ^pomen_GTR^ . Would like know even with body shift also cannot not be done on the satria Neo?
if bodyshift i think its possible... but better u compare side by side first before decide...
boyzone
2,669
5,148
Body shift can to support, but u will not able to shift up more than 2 fingers gap ... .:listen:
actually for rear is same as wira/ satria mount..just the body struts were longer a few inches
Good day all,
My car got out about 3 weeks ago, made some changes on it.
Well, now my boost reading is zero(0) when idling, when throttle a little, it goes down....then if boost it goes up a little...
what is going on???
Also would like to know if there's any difference on NA and Turbo throttle body.
The boost meter is in working condition as i tested with few other units of meter, and it's showing the same sign.
Even if i hose it straight from the throttle body hose, still...
