Water temp installation
gilos
141
hello guys,
need some help here...
i tried to wire up everything but it seems that the meter doesn't get any signal from the water temp sensor :(
what i did..
1. tap ciggie lighter wire and connect to (+)
2. tap ciggie lighter ground wire to (-)
3. wire up the sensor
4. ground meter body to dashboard metal frame
when i turn key to ON, needle goes up a little bit....means power ok(i think...)
then i try to heat the sensor with my lighter... the needle does not move :angry:
anybody can help?appreciate it...thanks :)
phat7
2,122
62
hi there.
Many possibilities. Firstly the lighter flame is in excess of 120celcius (max on ya gauge) use hot water.
gilos
141
it didnt max the gauge...needle didn't even move.. :(
maybe i'm confused here...thanks anyway :)
any other possibilities?? :unsure:
limau
533
maybe ur sender (sensor)unit not ground .eg. car engine, body ground.
just my 2cent
gilos
141
can i just tap ciggie lighter ground wire(black color) to ground the sensor unit??
is this correct?
or i have to ground it at the same point as engine ground?
limau
533
yeah ,just tab the cigar lighter ground wire will do the trick.
phat7
2,122
62
simply find any unpaited nut/screw on the car body should act as a good grounding point
gilos
141
okie guys...solved the problems hehee :D
sensor didn't ground properly...my bad...heheh
wire sensor and ground wire touching...causing short circuit(i think) and then needle shoots up to max(120degrees)..lucky the gauge didnt spoil.. :P
then ground it again properly...heat it with my lighter and needle steadily rise to about 80-90degrees...woohoo..
thanks guys :lol:
12oY
422
kuantan
u need use hot water to test la...and ur temp sensor will sense the temp slowly ma..... ;)
gilos
141
hmm..now i need to find an adapter in between the hose to screw in my sensor...
anybody know where i can find one?
gilos
141
sensor is already got with the gauge...
the only thing u need to get separately is the adaptor in between the upper radiator hoses to screw in the sensor...which is what i'm trying to find now heheh... :rolleyes:
like this one..see
ezwong2002
452
Butterworth, Penang
www.geocities.com
fren... fitting the adapter with ur radiator hose is a good idea.. provided the size fits... and it shouldn't block the flow of coolant travelling to your engine... i would strongly suggest u try to get a NPT thread (-t- ) fitting to your original water temp sensor together with your aftermarket gauge sensor... thats the best place to monitor water temp.
btw, i have the adapter for sale.. the one connecting via the radiator hose... around RM60. better looking than the picture u provided. cheers.
gilos
141
there's two NPT thread given(1/8" and 3/8")...but both also cannot fit ngam2 to the original water temp sensor...sigh... :angry:
that's why i am looking for the adapter...may i know ur contact no. & location...thanks :)
fark.. they broke into my car again! arghh!
this is the second time they suceeded.. same time, same wheather.. same place in front my house... 6am with slight drizzles.
amazing how they managed to smash my window without any sound!..
and again my player is gone (eventho i took out the detachable front panel)
i managed to catch a glimpse of them and wanted to give chase... but as i got out they threw the garbage bin and tiles at me and they fled! damn assh*les..
4 of them on 2 bikes...
