Installing Water Temp gauge
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
Hi fellow ZTHian, i have currently bought a water temp meter, but no idea on the wiring part,hope sifu can show me some guide:
I have the sensor install and go thru firewall
red, black, white n yellow wire
have check the under neadth of the dashboard, not sure how to tarik the wiring for 12V? can i sambung from the fusebox? how? :stars:
mines998
1,048
149
663
Red should be 12v
Black should be Ground
Yellow & white is sensor
If sensor already fix just tap 12v from keys. Normally 12v wire is red colour.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
u can tap from fuse that labelled as "clock" oso...since clock working only when ignition switched on....check the position by reffering to the fuse cover....anything that work when u switched on the ignition would do the same job....
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
thanks, manage to get it work:
but i not able to find the lamp light, so day time and night time same light :hmmmm:, do you know where can get the lamp wire? is it Radio and cigratte light there got this wire?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
ciggarate lighter port got light bulb/socket behind it....if u lazy to open dashboard center panel..then u try look for RH/LH light fuse socket at fusebox in the engine bay....
Anyone tried using one of these? Open up the valve will give a noisy ride but improve in power and closed it when you need a silent ride, but what are the problem known after installing it? can the electric motor stand the heat of the exhaust? All the sifus please advice.
