leaking water pump. really need help!
nyantong
nyantong
192
50
Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump.
However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
just change the waterpump if the pump already leaking....
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
Once water pump starts to leak better change. Work to take out also will take time....
