Upgrading my E3
icecream_van
Jan 20, 2011
6
Wassup all,
Firstly im new in this turbo/car stuff.Nw im using E3 engine with TD05H with all the stock parts(blowoff etc. etc.).The only thing that chng so far putting the wastegate (40mm).Just wanna get some advice on how to get more HP out frm the E3.What i should do first or change what or add what parts to gain few or extra HP...do let me know guys....:driver:
Mr.Garrett
Jan 15, 2011
15
Selangor
I've also the newbie like yours..just install E3 engine few month ago.Wat i've learn from my mech & some source of megazine first we look at wat we intend for?the usage of the car..daily drive or like a street racer..modification is depend on that.Its easy to increase the HP but there another thing u need to consider...For me,I don wan my car like a monster so I jz install a few items in term of fuel support system to avoid my engine premature detonation.So, wats is your intend for your modification? Maybe we can discuss & get another brilliant ideas from ours ZTH sifus..
[H] [K] [S]
1,130
616
Ermm...
Start off with fuel pump, stainless steel piping, boost controller, management/piggybag, injectors, cams, pistons, suspensions, tires, bigger turbines & the list goes on........ Depends on how deep your pocket is. However at the end of the day it's not the HP that matters, it's how you drive it. Power to weight ratio play a major part in determine whose car is faster. Anyways happy boosting!!
icecream_van
6
i jz wanna gain some HP and at the same time the most important thing is to maintain the engine as u guys know it im still a newbie..im not to sure what part is good for what as i know it im still learning the basics..not that i wanna mk it real fast or what actually..for a beginner like me what do u suggest i focus on more? cz sumone told me to maintain a tubo car that u drive daily its really hard..im not to sure what they meant by that....nway thanx guys for spare ur time to reply this...appreciate
mines998
1,048
149
663
What is the budget u have? Perhaps you can start with piggy back ECU to re-tune yr engine and go for higher boost. This is the fastest way to gain power.
kumar22mostwanted
1,562
152
HELL!!!
main thing is what is ur whp aim and what do u want to use ur car for
for example if its going to be a daily driven car
then better just cut out all the ideas on cams and giant turbos and just upgrade ur fuel delivery system with a better flowing fuel pump and adjustable fuel regulator and also exhaust piping for sure
[H] [K] [S]
1,130
616
To start off just get yourself stainless steel piping, fuel pump, fuel regulator, a piggy back & re-tune the engine to whatever set up you want......
Mr.Garrett
Jan 15, 2011
15
Selangor
This is the good ideas to start...
kumar22mostwanted
1,562
152
HELL!!!
at the moment my budget is nt muct...around 3k maybe...
for 3k the best bet for a beginning mod is :
1. emanage blue with ignition harness - RM 1500 (im not too sure this what i remembered last time should be around there)
2. Stainless Steel 3 inch exhaust piping straight all the way from the exhaust manifold to the muffler, remove the catalytic converter - RM 900 (it could be cheaper or more expensive, that is just how much i did mine for)
3. Apexi Power Intake Dual Funnel Air Filter + Heatshield + Cold Air Intake - RM 300
4. Balance service ur engine and gearbox if not done yet
happy modding :wavey:
mines998
1,048
149
663
E-manage was a very old version of piggyback ecu beside that there was a lot of replica in market you need to be careful when u buy. Stainless steel piping do not help to improve the engine power but using 3 inch piping do suiteable for E3 if yr piping is not 3 inch. If I not wrong Apexi funnel is 3 inch inlet which is not very suiteable for E3 infact it reduce yr horse power on dyno. Tested b4! If 3k for stock engine I rather buy Unichip piggyback ecu cos it guarantee you gain 15% above power for turbo engine and this will help u to get ready for next upgrade aswell!
[H] [K] [S]
1,130
616
3K?! SAFC, Fuel Regulator, Walbro Fuel Pump. Add bit extra if you do not have stainless steel piping for the intercooler.....
mines998
1,048
149
663
Now day if you have SAFC in car just don't anyhow park yr car! Sigh! This is the fact about Malaysia!
[H] [K] [S]
1,130
616
Been there.... 3 times ad my car been broken into.... So fix socket lar for all your gadgets. Also place it somewhere hidden. Don't show off too much. Just pray not the whole car gone missing.
Perak
rememberr always broo.............
---------- Post added at 10:28 AM ---------- 6 hour anti-bump limit - Previous post was at 10:27 AM ----------
remember alwys broo///////////
to all those sifu out there just wanna ask u guys .. wheter a W124 260E benz can fit a supercharger with its stock engine ??
