pls tell me wheres ground wire point..help me!!!
caqc12
301
can anybody tell me,,where actually the point i need to put at the car' s body......coz just bought the 7 point ground wire but i lost the installation guide paper...pls help me...
khguan
4,818
26
Seri Kembangan
fotopic.net
7 point grounding?? wat brand is your grounding kit??
1. bulk head(front beam of ur engine bay)
2. engine head
3. alternator
4. distributor
5. firewall
6. chassis
7. gearbox
enough?? heheh :D
pjs
9
Shah Alam
yeongk said:
If i not mistake it should be locate at the passenger side ... but not sure which area ... may be sifu's here can help out ...
Firstly, am I missing a point here but what car are you trying to ground? :confused:
simefly
449
Proton Wira ecu is located at the passenger side kick panel... the lil bulge there at where you leg rests....
simefly
449
Nope.. not me...scared i might fuse the ECU instead when grounding it...
pjs
9
Shah Alam
Nothing to be afraid of really. Look at the ECU carefully. There must be some kind of metallic bracket that is holding it up, right? if not, can you spot any metallic part with a screw that you can remove?
Well, just ground the wire to either the place where the ECU is being held (fixed) or fix the GW to any metallic part of the ECU.
No need to open the ECU - which I would advise you not TO!
pjs
9
Shah Alam
yeongk said:
So just ground to the matallic part will do right ??? any improvement compare to other point ???
Frankly, I do not feel any improvement even after having grounded the ECU - by the way, I drive an Avanza.
But than again, according to the GW sifu, the grounding of the ECU is supposed to only give back the power that was never there originally since the orignal grounding is questionable.
But this I can tell you, ground your gear box, the enigne block and the compressor ... and you can already feel the difference! :)
Hi guys,
Wonder if this was ever brought up. Anyways, I'll just ask.
Sometime when u enter other ppl's car, you'll notice a different stench/smell in every car. Like socks smell, coke smell, shoe smell, char kuey teow smell etc.
Is there anyway to eliminate the odor/stench/smell without having to pay a lot of money? I put charcoal in my car, but doesn't really seem to work well. Does putting those humidifier eliminates the problem?
Appreciate your advise
