DIY sifus pls help me with door actuator
kaokhao
9
My door actuator sometimes not working and i'm think to diy changing the door actuator(driver door actuator). I went to 1U Eneos to buy the door actuator but i found out there are 2 types of door actuator (2 wires and 5 wires door actuator). Which one to buy:confused_smile: ???Pls help me......thanks.....:regular_smile:
DarkAccoon
880
432
3,063
what car are u driving first lar
if wira then i suggest u dun buy those in enous
best is u buy from car spare part shops
cause wira's one is different
jswong
209
9
Wira original one is like a motor, it actuates the door lock rod by rotation. It's quite reliable and hardly fails.
The ones that accessory shops install are solenoid actuators that move up and down. The 5-wire version is usually used for the driver-side door because it can return a signal when you pull up or push down the door lock, to tell the central locking system to lock all doors or open all doors. The other 3 wire actuator is for the rest of the doors, whereby they only push or pull. You can use the 5-wire actuators for all doors, but only connect the signal return at the driver door.
If you have a screwed-up central locking controller, the solenoid actuators have a tendency to oscillate, shooting up and down rapidly.
kaokhao
9
me driving iswara...and i think i having a screwed-up central locking controller coz shooting up and down rapidly.So if this type of problem occured, i need to replace central locking controller or the door actuator? thank you DarkAccoon and jswong. Really appreciate all of your help....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
yaya... jz buy from spare part shop.... tell them what car u driving and they'll know what u need.... better than u buy blindly from accessory shops...
ledang
51
i had same problem on driver side, driving iswara too.. I brought new 1 from spare-part shop (rm45) and replaced it myself. problem solved.
duno where is the old topic went...so i just repost to share with u guys about my DIY heatshield just completed today.....
i took some plannings on cardboard before transfer the actual measurements to the paper and lastly draw it on aluminium sheets and cut + rivets them to shape....and lastly insulate it with superlon i had....
pics :
