MC on fuel injection cars
Jamrud
32
hi..anyone done MC to a fuel injection engine? results? Dis MC same concept as PowerJet..so shud connect to manifold intake rite? i dun knoe where to find my manifold intake tube...help plz...
khguan
4,818
26
Seri Kembangan
fotopic.net
just connect it to ur PCV hose... well.. for injection cars.. i think dat de effect onli few days.. then later de ECU will retune it back to normal... so u feel like normal again..
dats wat i feel lar... duno correct or not...
NiCkY7
821
hmmh... i think not...
cause fuel mixture is calculate from the air flow sensor... the air sensor is near TB there... and the MC is attach at PVC, how the sensor calculate about the MC extra air? ;)
:D
Jamrud
32
so, in other words, diy MC no good for injection cars?
sky_kids
141
Penang, KL
fixed mc in my car..
walau eh
the rpm reach 2k
then 1.5k
:S
then now better turn the air lower
now jus 1.5k-1k
help!!!!!!!!!
drexchan
2,908
100
Bukit Jalil
drexchan.fotopic.net
Originally posted by NiCkY7+Feb 9 2005, 00:59 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (NiCkY7 @ Feb 9 2005, 00:59 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-khguan@Feb 8 2005, 13:24
:D [/b][/quote]
let's take the new wira on Siemens ECU for example..
This version of engine runs on MAP sensor, not MAF sensor. Therefore any leakage into the intake manifold will cause an increase in the manifold absolute pressure (MAP). Thus causing higher indling speed. After some time, the TB servo motor will restrict the idling air by mean of further closing the butterfly. That's why the MC effect is temporaly.
But this do not cancel out the functionality of the MC. During gear shift especially, the MC helps to slow-down the RPM drop, which will give you more ohmps on the next gear.. That's the only effect i can feel from my DIY MC, which has been removed from my car.
About the A/F ratio.. since the system is running on MAP, the MC shouldn't updset the A/F ratio IF THE AIR LEAKING-IN IS OF THE SAME TEMPERATURE as the main intake stream.
I hope i do help..
delphinium
211
yupp.. it does help. I installed a DIY MC engine oso (MAP). the effect i can feel is oni slower RPM drop when shifting gear. Fuel consumptionwise ... no difference :(
can u please further explain about the temperature thingy. how does it effect A/F ratio? if either is not in the same temperature wat will epen?
drexchan
2,908
100
Bukit Jalil
because the air temperature is also taken into the calculation of A/F ratio. Air at different temperature have different volume. Of the same pressure, air at higher temperature will have lower volume thus lower flow mass.
when hotter air )which is most likely) is injected into the manifold through the MC, the measure temperature is still as 'cool' as the main intake flow. So the calculation might be upset by the small changes..
But i dun think it's of noticeable importance lar.. haha!!
menghua84
396
skudai/ perak
i hav a similiar device same as mc.. how much should i open the thing? since i duno how much to open it so i just hentam nia.. any difference if i open to the max?
cyrixMX
22
I've got the original Ecotek thingy installed on my citroen ZX. FC did improve as compared to before. I took out the ecotek for 1 week and FC rocketed sky high back to pre-ecotek days even I resetted the ECU. When I plug it back, FC improved again.
I also did a DIY version .. fuel hose 6mm (salvaged from old car-FOC), 1/4" stop cork (RM12) and mini open pod filter from COSPLUS (RM6.8). Installed it to my carby old school civic .. fulltank RM45 normally 400km only, after install I've finish 380km still got quarter tank hehehe .. u guy say got improvement or not la.
cyrixMX
22
ohh i forgot .. i unplug the vacuum hose for the air-cond vacuum controller (damper) and installed a 'T' there. Other than FC improved, now revving between 2-3k got the 'whirrling' sound effect. Car is more responsive as well.
for Citroen ZX (fuel injected), I unplugged the stepper motor bypass valve and connected the ecotek there.
tuning method, warm the car up and close the ecotek/MC thingy. when temp reaches normal running temp (the cooling fan spins for the first time). slowly turn the MC valve open until the whistling sound disaappear. Drive the car around and check whether the engine is normal. Letting too much air into the engine will cause pinging and finally "KABOOM".
Hi y'all......
Im not sure if this kind of topics have been discussed before. I've tried to browse all the forums, but it seems that this site is too slow...
Ok. Straight to the point!...
If any one of you guys knows where can i install a device(?) that allows me to start my car engine with a remote? If yes, where is the best place? FYI, i'm in Cheras area.
Thanks.
