how to DIY undercarridge LED light?
C
chilskater
Guest
can we 'reused' the LED(14LEDs) lampu picit as spot light?example..we take 2 lampu picit and stick together in fibreglass mould..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
sure can... as long as the LEDs arent burned... hehe...:_:
khguan
4,818
26
Seri Kembangan
fotopic.net
can... u wanto use as spotlight... get those 21 LEDs torchlight... better... 14 LEDs dun seem bright enough for driving purposes...
but make sure u get the right input voltage to the torch light...
kk9972
242
since u already got 12v LED, u can directly wire everything up in series or parallel connection....
remember add a fius at the positive terminal, jz incase of short circuit...
i planning to do so as well... but using 3.2v LED (normal rm1 LED sold in electronics shop)... need to add resistors and so on... hehehe...
btw, mind sharing how u gonna waterproof ur LEDs??...
Connect your fuis at ur battary rather than inside the car. if connect ur fius inside the car, short circuit will burn the wire.
shay
122
miri
khguan, hows the progress of ur LED?
Plz let us know the spec.
jaywat
1,329
khguan become damn expert already la.. from fluorescent light to LED undercarriage already
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
haha... why abandon la??... let us see the result ma... hahaha.... actually i also lazy do lar... i got the LEDs adi... all components got oledi... but, do i really need it??... will it affect my battery load??.... scared use too much power, battery kong vr fast....
ninja_iga
3,376
dude
so by using a resistor(s?) you can change 12volt to 6 volt?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
hmm.... if so, might try la.... install adi become lala chai also nvm.... hahaha...
*my friend say cars with undercarridge lights are lala chai car*
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
ninja_iga said:
dude
this i also not sure ler sifoo... coz as far as i know, resistor only reduce current... if to reduce voltage, u need a voltage regulator.....
wyx
46
to halve the voltage, try connect this way with R1=R2.
12Vdc --R1-------o-----6Vout
R2
Gnd
PS: connect R2 to Gnd at the mark o. I can't align the lines to its exact conenction :P
khguan
4,818
26
Seri Kembangan
fotopic.net
ninja_iga said:
dude
errr.. i guess using 680ohm should be fine... connect in series... but this is only applicable for LEDs as the load is very small... for stuff with higher current load, iti s not suitable to use resistor...
I'm trying to find Idemitsu engine oil around Kuching but seems like most of the spare part shops selling other brands. Anyone has any idea which spare part shop selling Idemitsu motor oil? Thanks.
