HELP! Waja High Beam cannot off!
richnet
21
1,503
Penang/PJ/KL
Hi guys,
I'm driving a Waja Campro 2006.
Last night, my headlamp's high beam just turned on automatically.
and no matter how i try to turn it off, by pulling the high-beam trigger, it doesn't shut it off.
it just suddenly on it by itself.
anyone faced such problem before?
any idea what's going on?
richnet
21
1,503
Penang/PJ/KL
bulb is not blown yet until last night, when i on and off the light non-stop, then suddenly one side not functioning, but the high beam still on... :(
i am thinking of temporary solution, which i just remove the high beam bulbs and let only the normal projector lamps lights, like that even with the high beam function on, it's still not on high beam mode from outside. but a bit dangerous lo, i cannot beam people...
NeuroOne
WFH
2,074
181
Putrajaya
i've experienced before (not Waja) that if the normal beam bulb blown, it will automatically ON the high beam to compensate the blown normal beam bulb.
are both your normal beam bulb ok? not blown?
richnet
21
1,503
Penang/PJ/KL
when both are on, all bulbs are normal. no bulb is blown. so, i find it weird.
i thought the relay is at fault, i tried replacing the relays, it's still the same... aargghhhh
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
like wat neurone said...the bulb has 2 filaments, 1 normal, 1 high beam.....the normal filament might been blown....
u only could notice it when u remove the bulb.
richnet
21
1,503
Penang/PJ/KL
waja is using H1 bulbs, which only got single filament inside.
normal + high beam = total 4 bulbs
richnet
21
1,503
Penang/PJ/KL
sigh... :(
the only thing I can thought of is the cable overheating and short-ed...
but then, I have no idea how to troubleshoot it myself now... well, can.. but it'll gonna take quite sometime
richnet
21
1,503
Penang/PJ/KL
aiya.. itu reliability issue... but this one macam weird weird eh... after 6 years baru ini macam...
hey guys i hav a budget of about 5-6k for my nissan sunny i got for free =)...
but now i'm stuck cos i'm not sure where 2 start from and how do i manage everythin under this budget...
ok 1st the problems encountered is when i drove this car back from klang without any brakes...damn dangerous i know but i was goin damn slow...i think the brake system 'keput' already...either the master cylinder o the brake booster hav 2 b replaced...
2nd problem is water leaking...tat wan should b common...
