help pls, fan belt / aircond belt "chirping"
headshot
160
Malaysia
Hi, I know theres is alot cars on the road facing same problem, the fan belt / aircond belt is making noise.
Mine happends after my mech change my timing belt :mad: it is damn annoying, no matter the engine is on idle or revving, it still making noise.
I called up the mech, he says just spray some lubs on the pully of the belt well after spray it just last 1 day then it comes again...i check on the belt, well it seems abit loosen coz can see it is fluctuating in spinning motion.
So is tat mech loosen the belt? can I make it tight again but adjusting the nut? or it is time to change the belt (it has been 50k without changing the belt)? Pls help.. thanks!! :D
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
loose belt or unalign belt/pulleys can generate the noise. try tight it again.
youmolo
208
Subang Perdana
www.tzywen.com
that's normal with new belts i think. but if only the timing belt is changed, it shouldn't happen. unless ur mechanic also adjusted ur aircond/alternator belts. there are commercial products out there to reduce squeeking, but personally, i haven't tried them out yet so i can't give any advice on that.
ierulink
36
Selangor
Better for u to check the belt tension. refer to your car manual on how to check the belting tension. if it's loose, tighting it might solve the problem.
satria_95
6,746
18
5,138
Malaysia
Try using Top Glide. Available from Brothers. Cost about RM9 or something like that. Drop it on the belt while it's running and listen to the sound either reduced or totally vanish. Been using it for years now.
KeonG
657
K.L ®
Bro, u applied ONCE then can last for few years or u need to apply the Top Glide certain time?
Furthest left,original dull state
Middle area (darker side) - Meguiars Gold class Vinyl detailer
right side - cleaned by Meguiars APC with brushes & quick detail Meguiars Gold class Vinyl detailer
conclusion only a clean surface bringing up brillant shine on the dash
the detail...
