FOG lights : keep standard or change it?
Seen a few in the websites but the problem is if it is credible (none of my frens used it before,so no feedback) secondly China products (doesn't last-led feed back was the little bulbs fails after a short period of time). That 's why I uses this forum check see any good recommendation and some actual feed back after use...hehehe. :biggrin:
That is why branded still better, like Phillips and Osram, but have heard from some, even these do not last as long as branded normal bulbs. Probably they burn hotter so shorter lifespan. Normal as in 55/60w or 90/100w normal bulbs
ken yeang
6,000 RPM
6,617
1,327
No point buying some cheaper lamps, but shorted very soon. Leaves nothing but bitter taste in the mouth.
The main reason to install these good lamps are for drivers' safety and practicality.....so invest on some lamps that are proven and worthwhile.
I wouldnt mind at all pay for cheapo stuff like sticker, for syoik only, maybe becoz of trend.
After the sticker fade, just throw away....and buy samore sticker. hahaha
I got a Carvox CX-990 ( aka Radiostar King-Eagle ) 2 way lcd alarm a 2 month ago. I got it installed and it was working fine. Now it got cold the remote starter will not start. It only starts when the engine is warm. What happens wile the engine is cold is: it will crank for a second and shutoff and siren goes off at that time.
I got the system on ebay and got it professionally installed all together $300+
I took it back to the shop they checked and rechecked all connections for 2hr...
