DIY Port & Polish Throttle Body (guide)
Jan 23, 2010
Fuel consumption? Better?! Or since the response better, so you accelerate harder... use up more fuel??!
TitanRev
You think I print money?
8,180
3,678
CARD, I didn't look much into the FC since it's not my priority...but the rev definitely seems more lively after the PnP.
TitanRev
8,180
3,678
TitanRev
8,180
3,678
digital caliper I have arturo...don't have DREMEL tools....actually how much is the price for a set of DREMEL??
arturo
nooB
2,721
1,083
SateCelupLand
i got a quote of RM785 for a dremel 395 multipro + a flexishaft + 55pcs accessory back in june...but i'm using a dremel 300 multipro (rm300)...the model before this + a 400pcs accessory set from rs-online for rm88 hehehe
quite hard to find suppliers who have stock on hand...the quote i got had a back to back order...so i'm guessing he had to order from the states then only send over the dremel.
Eh.. to those who DIY this TB polish, make sure you don't get overzealous with the polishing otherwise if your butterfly plate is smaller than the TB outake mouth, you're gonna have big time idling issues.
Izso...vaccum leak from the tips of the butterfly valve?
Yeap. My first TB I polish kilat kilat and I increased the throat size without considering the butterfly plate. When I face the TB against the sunlight, I can see a full sun eclipse one.. very the bad. Idling was crazy!
2nd TB the 'eclipse' was much smaller and lucky for me it didn't cause any idling issues.
fstr
7,935
954
Sahara Desert
TR taikor, after u did d porting a bit... did u feel any difference in acceleration?
I thought this would be the PERFECT test car for the Castrol Edge as being an old car, this will really test out its protective properties. Also, it’s a heavy car with a 2.8cc engine so fuel consumption is generally on the high side. Since owning the car in December 2009, it’s been running on an average 6.3 – 6.4km per litre of fuel. It’s on a strict diet of RON95, being my daily drive and the ever rising cost...
