DIY Port & Polish Throttle Body (guide)
TitanRev
You think I print money?
8,180
3,678
unker, I both top and lower part is port.....only satisfied...if port only 1 place result not so satisfied.
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
team99ers.2.forumer.com
but now, u just port the outer part, haven't port the inside part.... mayb after port the inside will get better 'feel' ler..???:proud:
fstr
7,000 RPM
7,935
954
3,213
Sahara Desert
i only port the bottom cos i need more low end for my auto.
results after porting is good, some feel is noticed. :biggrin:
fstr
7,000 RPM
7,935
954
3,213
Sahara Desert
:biggrin: :biggrin:
dont dare to port too much, this is my spare tb.
have another spare tb, and this time gonna port kao kao :nurse:
samurai76
Feb 8, 2013
26
503
TitanRev san...two thumbs up...:rock:...recently, i cleaned the throttle body by using carb cleaner...then, I found out your DIY....this would be my next DIY project...well, how long it takes to polish the inner TB ??....
Be careful when doing this. Don't overport until the butterfly flap cannot close properly. If there's leakage your idling is gonna be a pain in the ass.
I ported mine and if you lift it up into the sunlight you can see an eclipse around the butterfly. Lucky for me it didn't affect my idling much
TitanRev
8,180
3,678
s76, I did it by hand so it was quite a long process...probably will take you 7 to 8 hours for the whole process...I'm also going to be doing another TB for my other car...
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
:adore: sifuses & bros, if i'm not mistaken, the butterfly should fully closed when tb is cold but mine is not, is this a prob that needs to be solve??:confused::banghead:
What do you mean not fully closed? Is the flap spring pulling the butterfly closed or just half way or slightly open? If slightly it might be on purpose depending on what car you drive. It can't be completely sealed otherwise your car wouldn't be able to idle.
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
hmmm, maybe later on i'll take a picture & post it here, btw thanx for your kind opinion hope i can learn more & not just drive & clean my wallet when the time comes:adore:
hi all sifus,
i wanna lower down my serena C24 by 1.5" - 2", just for the sake of good
looking.
just wanna ask, can i just cut off the original spring? will this affect
the comfordness?.
just when to a workshop...FTS Motor works in Ipoh, the owner himself is a
drag racer, he advice me to just cut off the original spring and he will
modify the absober (shorten it) for me...
thank you very much!!
