[DIY] Easiest DIY of all - how to change engine oil
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
last weekend changed my kancil brake shoe wit try & error method, since doing it alone for the 1st time I didn't had the chance to take pictures of process. took me 4 hours to manage to finish it when it should be faster than that if let them mechs do it. it all went smooth for the right hand side, just an hour I think but all went havoc for the left hand side, no problem opening it but to install it back caused me problem. y coz 1 of the item with the spring popped out & I manage to install it back but the wrong way. I put it back like the right hand side but actually it's like the mirror side of it. how did I know, I re opened the right side compare them parts & :banghead: 2,3 times & manage to finish it. maybe I could cut back an hour if I used my other 2T bottle jack in kelisa instead of using them bricks:banghead::banghead: & luckily no other parts r damage. it's not that hard for kancil but don't know with others cars, next my kelisa, hope it's the same method. but all in all, anything diy is truly satisfying.
Wah, i changed my brake pads myself but shoes are on a whole different level.
like I said for kancil its quite easy but for bigger cars maybe mechanism is on a whole different level edi
Bigger cars normally will have disc already in the rear, but then the disc also can be very different but still easier then shoes.....
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
ATF I think more complex, can use in PS but not the other way around....
I use PS fluid or ATF for my K & N last time....
Ya as oiling like you said right? My KNN i just wash and reuse already. Didn't oil.
Might get some ATF to use it as oiling. Since I have leftovers for servicing kelisa haha!
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Yup, K & N filter, the filter element have very coarse opening, so need oil to trap fine dirt....
Damn la, means need to buy the oil then.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I went Commando style for my 206....running trumpet without any filter on it....damn kao brave the mech said to me...1st time he sees people running trumpet on 206...
Put netting or ladies stockings in the front......:biggrin:
TitanRev
Mar 3, 2005
8,180
3,678
I got put my wife stocking but it somehow tear open after a week....Then I put 2 layer....
TitanRev
Mar 3, 2005
8,180
3,678
i have seen many ppl actually change their engines once their crankshaft breaks, mostly related to campro engines
so my question here is, does the broken crankshaft actually damage the engine block once its break and render the engine useless or these ppl here just wan to get rid of the campro engine and swap for a mitsubishi engine while actually the crankshaft can be just replaced and the existing engine works as fine?
