[DIY] Polishing B.Caliper & R.Cover
loose_end
3,649
197
Malaysia
Brake Caliper
- Dusty calipers
- Tools needed to polish
- Brushing with soap and wipe
- Painting the wording.
Rocker Cover
- Before
- After
alantjw
1,566
128
nice wan but my brakes are Karat color how ar??
Lean
UnderCoverProject Founder
221
12
undercoverproject.blogspot.com
You can't apply it too hard on the surface as it will scratch of the particles or surface layer on it. I think it is better to use degreaser to clear it off. Just my 2cents.
prince of speed
65
40
so does anyone have an idea on how to spray the calipers? i wonder what kind of spray can be use and can u just spray it directly with dissemble the calipers? any thought?:idea:
It's quite easy la. Jack up your car, put it on jackstands, take out the rim, make sure you clean the caliper and rotors very clean with soap, brush and water. Let it dry completely and just mask off the areas you don't want to kena spray with tape and newspaper, then just spray.
If you can find high-temp black ore high-temp red (very rare) just use that. Otherwise any Nippon paint spray from ACE is good enough, those will last for a while but don't forget to spray clear coat also. Helps a bit.
kcng
734
235
1,543
Selangor
kcng1983.blogspot.com
izso, can u do it for me?
i buy u breakfast...
:biggrin:
mdjames
104
41
Spraying won't last even using high temp spray paint. If you want the paint long lasting, powder coat is the way.
szekeiemme
3,749
5,138
next step is to polish the valve cover with autosol, more chrome effect!
Jai_RS
315
Kemaman
Perhaps u should apply an undercoat....
alantjw
1,566
128
i question tho.. ur using Nissan Brakes on a HONDA???
pwhyze
924
356
1,563
Using Nissan caliper on a Honda is pretty common, especially R32,R33 brake calipers. Looks wrong though, haha
Veloc
3,234
991
Sabah
I sprayed my valve cover just a can of normal "crystal" brand spray. I expected it to come off fast and I will send it to a paint shop. But it has been a year now @.@. Sometimes I really wonder does one need a high temp primer and paint.
Oh one thing, surface prep is very important. If the area is really rusty and greasy, might want to try paint remover. It's kinda harsh but it does the job. Gives the paint a fresh bare surface to adhere better.
Well, i'm a newb at modifying cars...i'm driving a wira 1.5 everything stock and it sucks like shit...i want to improve the power but i don't know how...but there's a few constraints such as i don't want to change engine.. any other ways?? cheap ways la if can...and without going through jpj as well....
