Accent Modification
Fluffy
3,870
>>klang<<
chejeff said:
Mind if you could elaborate more? may i know what is NA tune? What type of tuning they do? where could i do it and how much would it cost? sorry for being so noob :P
NA tune he means is that u keep ur engine NA.not turbo charging it.
chejeff
98
Fluffy said:
basically wat u want in a exhaust is the size.the ideal size will give optimum performance..not too big not too small..the sound?u've gotta go to a exhaust shop and ask fr urself..coz i dont know wat kinda sound u want.
for the intake..go for the steel one.with the apexi filter..better intake.
but u;ve got 2 options..CAI or air ram.
what is the diff? which will perform better? how much budget should i prepare for this mod?
Fluffy
3,870
>>klang<<
CAI is cold air intake.means it feeds cooler air (which has higher density) into the combustion chamber..colder air has higher density..so there's more air to burn when ignited.hence a gain of power.
Air rams are used to ram air into ur combustion chamber..this concept is to stuff in as much air possible into the combustion chamber so that it can combust better hence more power.
'[00] TRD
342
CAI is the one like mushroom head one rite? i tot sumbody quotin that would cost yr car hp instead if it doesnt fit properly (i mean like size thingy)
bside it will makin sum bassy sound in the engine compartment though
Fluffy
3,870
>>klang<<
the mushroom shaped one is a called an open pod.the shape of the filter doesnt matter...but open pod is basically an air filter tat has no cover around it.hence the name open pod.
CAI is an open pod..with a heat sheild.the heat sheild is obviously to block the heat while enabling the filter to suck in cooler air.
bassy sound?the exhaust?or the open pod?
'[00] TRD
342
bassy sound is fr the cone air filter, acc to my fren drivin kancil la.. i never seen a open pod one leh, how does it looks like? or i seen it before but nvr notice that??!?!?!
Fluffy
3,870
>>klang<<
open pods are the one that ur talking about now.the cone and mushroom shaped ones.yes..they produce a suction sound..not a bassy sound.
chejeff
98
So does that sound thingy sounds good or plain noisy?
Fluffy
3,870
>>klang<<
sounds nice actually...well,u've gotta hear it fr urself.see if u like it.its basically a suction sound.
Recently DIY flushing radiator coolant myself and come across this two types of hose clamps
1. View attachment 574416 Original Constant tension band hose clamp come from factory (Honestly I really don't know what it call:dontknow:)
2. View attachment 574417 Scew type hose clamp
Which one better? Which one will you choose? While changing radiator hoses, will you take out the original one and change to the screw type hose clamp?
- My own opinion is the 1st original one is better than 2nd...
