Wira SE modification tips?
Dec 10, 2020
4
Hi to everyone, is there anyone here still rocking on a wira in 2020? Would like to know any modifications guide / maintenance I should do to get some performance in my old wira hehe. Since the car is quite old and I think I should do some maintenance of the car to keep it running good. Is there any DIY cleaning or maintenance I should do?
Things I already done:
- Cleaning spark plugs
- Engine Bay cleaning
- Fuel Filter change
- Engine Oil & Oil Filter Change (Motul 4100 turbolight)
- Radiator flushing
Mitevo7
Mitevo7
1,446
177
- Radiator flushing
What engine ? If it's N/A there's really very limited performance gains from thousands of ringgit spent. If you have a manual one, skimming the flywheel, install better clutch is a good start. After that, get a piggyback or standalone ECU with anti stalling feature, remap the engine that compliments to all the mods you did. That should gives you pretty nice engine characteristic.
After engine, don't forget your suspension, change all the shocks, rubber bushings. Power is nothing without handling.
Uncle Tofu
4
A manual 4g15
ixeo
ixeo
4,787
3,080
KL, Malaysia
Modification?
ignore everything you hear. The most important mod is
1. tyres
2. Tyres
3.tyres
4. Tyres
5. Recaro seats
minibeany
minibeany
559
82
28
Modification?
1. tyres
2. Tyres
3.tyres
4. Tyres
5. Recaro seats
agree. tyre and stability of the car.
When you're trying to push your 4G15 to limit... means sometimes driving at higher speed. With modern cars you can take some corners easily on high speed. But do take the corner on the same speed, you will need a metal ball on 4G15. hehehe...
15,344
6,403
- Radiator flushing
Which WiraSE model is yours? 1st batch manual? 2nd batch manual? Each batch had different equipment. All had the rubbish JRD 16" rims though.
Only the first batch SE had a muffler, front springs, extractor, interior, body kit, rear ARB, rear disc brakes and 16" rim. Most later models didn't get anything except the rims and muffler.
The Wira SE front spring is very unique but considering how old it'll be, it's probably sagging now. You may want to look at aftermarket coilovers. After market antiroll bars (front and back) would help with handling too. There's a few bars from UR that are great - the fender bar, front and rear strut bars, side bars.
The Wira SE rear muffler is actually a very good muffler. The only problem is the material it's made of is rubbish so it probably would've corroded by now. The Wira SE extractor is also very unique, if you don't have this then a good 4-2-1 extractor, change to 2" piping and a straight flow rear muffler would help. If you want add in a straight flow pillow type resonator to reduce drone.
Brakes pads (front and back), change to a lightweight 15" rim, use good tyres like Federal RSRR 205/50/15 would change the way you drive.
Finally - the 4G15 is a very simple engine and the VDO ECU is a pretty smart ECU. Got money consider a complete transplant like a 4G93 mivec or turbo. Not much money, get a 4G18 Waja crankshaft, the campro piston combination to oversize and stroke your engine to be about 1.7L. Get a proper standalone to control everything and one of the cheaper ones that you can opt for is MaxxECU or ECUMasters.
  • Like
Reactions: minibeany
sweelt
sweelt
Nov 6, 2016
2,292
246
663
Penang
Can also search back some old thread. Got many threads on them......
2nd this, check on old thread.
Always think of handling first.
If easily satisfy with simple mod to push 4g15 then no problem.
If hungry for more, drop in mivec or 93t legally. No need waist money and time mod 4g15.
Tepuk dada tanya sendiri.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
But most will go through the stages, myself included. Air filter lah, high end spark plugs, plug cables, extractor, decat, etc. etc. Then later feel the power of forced induction, all those mod actually waste time only......lol
kevyeoh
kevyeoh
51
forced induction = turbo? i read that turbo probably harder to maintain or maybe prone to issues more frequently, is it true?
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
As far as I know, if you BOT (bolt on turbo), probably will have more issues as the engine parts are not meant to be turbo-ed. If you do an engine transplant meaning transplant a turbo engine in will be better. Again, another issue is driver and usage. Mine is daily driven and now is 20 years since it was transplanted. As for maintenance, is the same. Oil change and whatever. Probably more expensive provided you use better oil like full synthetic and probably a more frequent oil change interval. Other than that, probably failed parts. Even with slightly heavier maintenance the trade off is the turbo power you get.......lol
15,344
6,403
forced induction means anything methods of forcing in more air into your engine. Meaning turbo or supercharge both are characterised as forced induction.
harder to maintain? No la. Same, just that potentially you need maintain more saja.
