Accent Modification
chejeff
chejeff
98
Is there any modification interms of interior , exterior and engine modification? Is there any available engine that could fit in the accent engine bay?
WHat is the recommended modification that could improved the performance of the car?
sylkhannaz
sylkhannaz
389
Selangor
if you're goin for a hyundai engine maybe u should go with Beta engines from hyundai. Maybe from Tiburon(hyundai coupe) or elantra.
i wish i can help more. go to http://www.hyundaiperformance.com. there's a lot of info there including mods and swaps.
gavan
gavan
1,408
Shah Alam
enter EVO engine terus ;) i heard there is one sonata with evo engine around also :P ehheheheh.....
chejeff
chejeff
98
EVO engine? are you joking or for real? can it really fix in without any major modification?mine is accent wo, not sonata. is the mouting point same meh?
btw my car still new... not looking major modification like engine transplant. i juz look for minor modification that could help in increasing hp. eg.open pod, muffler etc.
but i juz dunno where do i start with. i wanna try to mod it to only increase hp without being look as ah beng car. Eg. Changing a ekzos that even a human head can fit in n the vroom is so loud till next street can hear but no power.
any idea?
Fluffy
Fluffy
3,870
>>klang<<
with money anything is possible.but JPJ and PUSPAKOM 90% wont let u take the car on the road.
sylkhannaz
sylkhannaz
389
Selangor
earlier versions of hyundais use mitsubishi's platform and engines. so, they might have a similar mounting to mitsu. like protons. he's not joking. :)
Fluffy
Fluffy
3,870
>>klang<<
reallly?now that's a shocker.haha but im quite sure the conversion might be a lil susah to be approved..IMO la..
Maxx
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
yep. earlier hyundai using mitsu. technolgy.
theres a transplanted hyundai coupe with evo4 engine inside.
Fluffy
Fluffy
3,870
>>klang<<
ahh..i see..thanx fr da info btw.hehe
so..for fellow accent owners..there's a very GOOD option of conversions..hehehe
chejeff
chejeff
98
Ok that's on the engine part.
What type of modification that could increase HP w/o having to do major mod such as engine transplant? in another way to say is, cheaper option for hp increase.
some example such as- changing a high performance air filter(open pod)
- Change exzos/muffler
Fluffy
Fluffy
3,870
>>klang<<
do ur intake and exhaust.
*intake - cold air intake or air ram
then port and polish ur engine.
chejeff
chejeff
98
escaflowne said:
Stage 1 Na Tune Lorr..simple Enuff
Mind if you could elaborate more? may i know what is NA tune? What type of tuning they do? where could i do it and how much would it cost? sorry for being so noob :P
do you hv any recommendation for the type of exhaust that will not sound too ah beng but more power? if i would want to mod my intake to open pod, should i use aluminium or steel air tunnel with k&N filter or apexi?
Fluffy
Fluffy
3,870
>>klang<<
basically wat u want in a exhaust is the size.the ideal size will give optimum performance..not too big not too small..the sound?u've gotta go to a exhaust shop and ask fr urself..coz i dont know wat kinda sound u want.
for the intake..go for the steel one.with the apexi filter..better intake.
but u;ve got 2 options..CAI or air ram.
Fluffy
Fluffy
3,870
>>klang<<
NA tune he means is that u keep ur engine NA.not turbo charging it.
chejeff
chejeff
98
what is the diff? which will perform better? how much budget should i prepare for this mod?
Fluffy
Fluffy
3,870
>>klang<<
CAI is cold air intake.means it feeds cooler air (which has higher density) into the combustion chamber..colder air has higher density..so there's more air to burn when ignited.hence a gain of power.
Air rams are used to ram air into ur combustion chamber..this concept is to stuff in as much air possible into the combustion chamber so that it can combust better hence more power.
'[00] TRD
'[00] TRD
342
CAI is the one like mushroom head one rite? i tot sumbody quotin that would cost yr car hp instead if it doesnt fit properly (i mean like size thingy)
bside it will makin sum bassy sound in the engine compartment though
Fluffy
Fluffy
3,870
>>klang<<
the mushroom shaped one is a called an open pod.the shape of the filter doesnt matter...but open pod is basically an air filter tat has no cover around it.hence the name open pod.
CAI is an open pod..with a heat sheild.the heat sheild is obviously to block the heat while enabling the filter to suck in cooler air.
bassy sound?the exhaust?or the open pod?
'[00] TRD
'[00] TRD
342
bassy sound is fr the cone air filter, acc to my fren drivin kancil la.. i never seen a open pod one leh, how does it looks like? or i seen it before but nvr notice that??!?!?!
Fluffy
Fluffy
3,870
>>klang<<
open pods are the one that ur talking about now.the cone and mushroom shaped ones.yes..they produce a suction sound..not a bassy sound.
chejeff
chejeff
98
So does that sound thingy sounds good or plain noisy?
Fluffy
Fluffy
3,870
>>klang<<
sounds nice actually...well,u've gotta hear it fr urself.see if u like it.its basically a suction sound.
