Modify Clutch height ? Now my gear cant shift
sentro
32
Hi all,
Can i know how to modify clutch cable to adjust the heigh ?
ok, there is one rubber, and 1 yellow color screw rite ?
we shift clockwise mean it'll tighten and move inside.
What is the right way to adjust ???
Justnow i loosen the rubber, then pull the cable, then i shift anticlockwise to the screw so it'll go outside ....
then i press my clucth the gear cant shift liow !!!!!
then i do do do, the clutch too low till i move 0.01cm the car can engine die off
hope someone is generous to guide me :cry_smile:
huakenny
LB Performance
9,126
240
Kota Kinabalu
tight it back as how u loosen it..
leave it to ur mech if u not familiar wit tat...
my mech help me adjust those thing for FOC, so y so troublesome go do urself if ur mech can do for u FOC?
my2cent
sentro
32
not much mechanic in my area, furthermore i wan learn ma.
ok i tight it back oledi now can shift gear.
But actually how do we adjust ??
untight the rubber, then the clutch height is depend on the screw or wad ?
Jun 23, 2007
4
If u adjust the clutch too height , ur clutch pedal no free play .
It probability to burn ur clutch ...
sentro
32
hmm i tot the height onli can adjust from the cable rite ... after open bonet near the injector there
Btw, the heigh of clutch is it affect from the rubber or the screw ??
u mean the rubber too tight clutch burn ? i put it quite tight wor ... but my clutch is not too low also ... so how ah ?
RedD
644
3,018
anywhere..
shit lo like tat... mine like no gap wor...
n i remember tat time my mech help me adjust it.. n ask me to sit inside to feel the clutch.. then i sed ok..feel better..coz last time too low d... then he told me tat adjust till max d... =.="
so..wat shud i do nw?
RedD
644
3,018
anywhere..
satria...hmm, mebbie i'll ask bek my mech to lossen it a bit..
btw.. mind telling me where izzzit? the cable thingy..
sentro
32
need confirmation :
1) is it the rubber mean to loosen the clutch pedal gap ( between the resistance point)
2) is it the screw determine the height ? if so, if i need my clutch lower, how should i adjust screw ... need DIY today haha.
Btw, i think if no ressistance gap nothing kua. Unless you awiz put ur leg there to rest la, then mayb u tertekan the clutch a bit so consider makan loh. If got resistance, u put ur leg there to rest still not kena .
okay.. decided to get a toyota vios....
Plz tell me what can i modify...
in terms of the LOOKS, PERFORMANCE and ICE
i hav 10-15k budget... i would like to divide the money into all 3 categories...
so mind to share??
what good ICE can i put for 5k?
any bodykits ? any nice sample pictures? hoods? and so on?
performance wise.. supercharge? turbocharge?
I do not wish to implant another engine as im buying a new car
plz do help out...
wanna set my plan out
thank u
