Waja 2001 standard to modify
thomzcruz80
Oct 1, 2011
38
508
Kuching
My ride,Waja 1st model sohc still in good running (engine). I intend to convert to GSR or Mivec but still sayang my engine still move smoothly can reach 160rpm (auto).
How bout if i juz upgrade adjustable cam pulley,crank pulley and cam shaft?
How bout oil consumption? HP? Any opinion guys?
mant53
13
1,503
you mean 160km/h??
what u intend to do with ur car?? high revving all the time?
high cams will give more power but ur low end would be a bit sluggish...
to me, when u use high cams, u'll be more on higher rpm.. so higher rpm, higher fuel consumption...
p/s: correct me if i'm wrong.. :)
ehdrian
I Don't Care!
3,310
280
1,683
Penang
wat is ur targetted hp?..wat is ur budget?..
thomzcruz80
38
508
Kuching
Mant53: Wat i mean is even my engine stock no modification,it can reach 160. That bcoz i not cancel to upgrade gsr o mivec engine.
ehdrian: No target ast ol bro...juz wana powerful engine. Surveying recond engine but mine still ok. So,tryin to upgrade high cam,cam pulley n crank pulley...
mines998
1,048
149
663
If no target is difficult for people to give you advice...what is consider powerful engine to you?
thomzcruz80
38
508
Kuching
Power engine 4 me is more power than my old stock engine. Just for daily use...not race. Stable engine i mean.
---------- Post added at 10:01 PM ---------- 6 hour anti-bump limit - Previous post was at 09:57 PM ----------
convert to manual. sure can bypass 160km/h.
Yup.gud idea..shiftronic?
arrowhead
4,621
152
5,163
Damansara/PJ
i think manual would be more responsive, nv tried the tiptronic before tho. no comments on that
ehdrian
I Don't Care!
3,310
280
1,683
Penang
TS got very low expectation only, easy la..
aHLengChai
380
53
no target?
then upgrade intake & exhaust enough..
to make the engine run more smoother..
agreed.. just do standart modification la bro..
extractor..muffler.. center bullet.. manual trans..lighten flywheel..lighten rims..lighten body(cf)..lighten..ecu management blablabla..still reliable to daily drive..:biggrin:
lameshit
Sep 17, 2011
45
4
508
Johor Bahru
Saving on your bucks? Try to high cam your pistons
And change th exhaust intake 421, provide you with sufficient power as well as efficiency
any of u guys encounter such prob? where your aircon doesn't seems to be cold when the car's stationary.. but when the car's moving.. itz darn cold like fridge?
any idea whatz the prob? cannot be run out of gas ah.. coz if out of gas.. it wouldn't be cold when the car's moving.
