4g13 talks
Latebloomer
89
4
27
Valve seats sorry. Basically incomplete combustion busting out.
Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seats
how long would it take? and the costing?
parakey
1,367
226
He was previously thinking of an engine change. Best to monitor first to be doubly sure.
Out of curiosity, what is the mileage of this engine?
parakey
1,367
226
Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restoration
Mileage plays an important part in gauging whether it's valve seal or piston rings. If piston rings, it's a complete overhaul. If it's just valve seal, you only need to open the engine head.
parakey
1,367
226
Here's an example of valve seal replacement without opening the head
Latebloomer
89
4
27
Thanks bro.. will find out of the cause of it. Any update will be inform. Spark plug already change few weeks ago.
minibeany
598
102
543
mine 20 years at 160k km...
no issue with the rings and valve... touch wood.... choi... choi...
Reactions: sweelt
Latebloomer
89
4
27
Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into it
That will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..
parakey
1,367
226
Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the car
Hi Guys,
Recently I got a pair of Toyota Koito OEM Ballast which originally come with D2 Sockets..
I have done some DIY modification by replacing the existing balast with this OEM on my 9006 (HB4) HID Bulb.. after connecting the balast with my bulb... I was able to firing the bulb but after a couple second it goes off.. I have repeat the process several time and it keep on goes off after firing for roughly 10 seconds...
Balast- Toyota Koito OEM Balast - D2S Socket
Bulb- 9006 (HB4)...
