4g13 cab engine
dariusw
Dec 26, 2010
23
Need advice frm all the sifu on how and what things need to be mod to increase up and torque for 4g13 cab engine. Now it can only reach 140kph max for a 7 yrs old engine. Thinking on I increasing the hp and torque. So need advice on what can be done. FYI, been using K&N air filter and extractor is 4-2-1 all this while. Any advice.........
dariusw
23
Changing block to 1.5 or straight away swap to 4g15 engine which one is more cost effective? By the way on the FC, which one is better cab or EFI? If straight away swap to EFI 4g15 does it require to change the whole wiring?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
change the block only will cost less as other components are similar with 4g13....
generally in healthy stock standard form, fuel injection is slightly better in fuel consumption... but it all rains down on ur right foot... if u aim for good fc, make sure engine healthy (regardless carb or efi), correctly tuned and discipline ur right foot...
swap from carburetor engine to fuel injection engine u need to add the engine wiring harnesses... engine wiring is not same with car wiring for electronics component....
dariusw
23
Will it be significantly diff once chg to 1.5 block and also do the pnp? Any recommended place to buy the 1.5 block?
I only having RM7K to buy a car.
Is a Kancil with a L7 turbo a nice bargain for Rm5.5K?
Any pros and cons for the car?
I live in JB is it sourcing part for L7 turbo hard?
Hope some sifu can help
Although I still look for other car like Wira 1.5/1.6
Corolla seg 1.6 those a more likely over my budget but will still look for it.
Currently own a Honda Jazz due to some reason need to gv it to my dad. But he only gv me so little $$$ to find a car
Update_Had bought a Wira Vdo Auto 1.5
Now is...
