- May 19, 2020
- 89
- 4
- 8
- 27
Noted.. will monitoring on that. Car is running smoothly btw. Just that the smoke are unpleasant to seeNo need to panic so quickly. Monitor your oil consumption and condition of your spark plugs first
Valve seats sorry. Basically incomplete combustion busting out.Valve guides?
Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seatsNoted.. will monitoring on that. Car is running smoothly btw. Just that the smoke are unpleasant to see
how long would it take? and the costing?Valve seats sorry. Basically incomplete combustion busting out.
He was previously thinking of an engine change. Best to monitor first to be doubly sure.Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seats
Mileage not sure.. wat i do know the car is 15 years oldHe was previously thinking of an engine change. Best to monitor first to be doubly sure.
Out of curiosity, what is the mileage of this engine?
Isnt is displayed in your odometer?Mileage not sure.. wat i do know the car is 15 years old
Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restorationIsnt is displayed in your odometer?
Mileage plays an important part in gauging whether it's valve seal or piston rings. If piston rings, it's a complete overhaul. If it's just valve seal, you only need to open the engine head.Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restoration
Thanks bro.. will find out of the cause of it. Any update will be inform. Spark plug already change few weeks ago.Wira Replace Valve Seal
One Wira come and visit us because of his Wira having white smoke from exhaust usually this issue is engine burning engine oil we decided to do the lowest cost repair job Replace valve seal without…mrmoworkshop.wordpress.com
Here's an example of valve seal replacement without opening the head
mine 20 years at 160k km...Mileage plays an important part in gauging whether it's valve seal or piston rings. If piston rings, it's a complete overhaul. If it's just valve seal, you only need to open the engine head.
Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into itmine 20 years at 160k km...
no issue with the rings and valve... touch wood.... choi... choi...
That will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into it
Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the carThat will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..
Like i said.. not planning to change the car nor the engine.. but the block mayb..Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the car
