4g13 talks
Latebloomer
89
4
27
Valve seats sorry. Basically incomplete combustion busting out.
Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seats
how long would it take? and the costing?
parakey
1,367
226
He was previously thinking of an engine change. Best to monitor first to be doubly sure.
Out of curiosity, what is the mileage of this engine?
parakey
1,367
226
Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restoration
Mileage plays an important part in gauging whether it's valve seal or piston rings. If piston rings, it's a complete overhaul. If it's just valve seal, you only need to open the engine head.
parakey
1,367
226
Here's an example of valve seal replacement without opening the head
Latebloomer
89
4
27
Thanks bro.. will find out of the cause of it. Any update will be inform. Spark plug already change few weeks ago.
minibeany
598
102
543
mine 20 years at 160k km...
no issue with the rings and valve... touch wood.... choi... choi...
Reactions: sweelt
Latebloomer
89
4
27
Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into it
That will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..
parakey
1,367
226
Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the car
I'm thinking to DIY an ICE Cap, I have plenty of capacitor on hand, ranging from 47uF to 10,000uF. Total 65 pcs, 9 different types of capacitor, all rated at 16V and 85deg Celcius. Bought it to DIY stun gun but in the end, project failed...
The total capacity is 152,110uF, i believe it should be big enof for an ICE cap... using 20A fuse.
The finish product should be connected directly to the amp? (paralle with amp)? any things that I have to take note?
