minibeany
598
102
543
this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahaha
you suggest to get a new radiator? if the radiator causing the rust. how many mm? double layer aluminium?
sanekit
Dec 9, 2015
1,616
157
usually after flushing and then add coolant, if there's still rust, it's from the water passage inside the block. u will need to remove water pump, thermostat and water plug at the block side and do chemical flushing to remove all the rust. then radiator send again for service and cleaning. should be able to clear the rust out that way.
While Ferrari’s latest flagship is pulling in all the attention mainly due to its concept-esque shooting-brake body style and al-new V12 nuclear-plant of an engine, its four-wheel drive system should be given its fair share of the limelight as well, particularly considering the high-tech way it functions and the being the first Prancing Horse with four-wheel drive.
For those that don’t speak geek and...
