i throw cigg butt ...He opens his window to manually throw sand
How do you flush the radiator? Unplug the stopper at the bottom or remove the top hose?sifu... how frequent do we hv to flush this Wira radiator? mine became muddy again. sob... sob... View attachment 577915
I use my coolant for at least 20k km.sifu... how frequent do we hv to flush this Wira radiator? mine became muddy again. sob... sob... View attachment 577915
whoa. this is same case as mine. need to do full flushing service for radiator and block and change the water jacket and bypass pipe.sifu... how frequent do we hv to flush this Wira radiator? mine became muddy again. sob... sob... View attachment 577915
this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahahaI use my coolant for at least 20k km.
What i did is fill in 100% premix coolant. only top up with water if coolant level reduced. i discover from another car within my family that using only one bottle of coolant and top up with water is not good for long term.
Using 100% premix is kinda expensive depending on how one look at it. My BLM radiator only hav very minor rust recently as i failed to do periodic check on coolant condition. Mind u thats the same radiator since at least 5 years ago. My waja...thats the same radiator since 02, cant check as it has no cap but coolant in reserve tank is still green and no rust sign.
I also discover that the new proton blue coolant will loose its color quickly. It does not seems to lose its anti rust properties or cooling ability which is good.
You use water only or with coolant?sifu... how frequent do we hv to flush this Wira radiator? mine became muddy again. sob... sob... View attachment 577915
Time for a fresh start with a new engine then....poison..poison..this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahaha
swap engine if halfcut, always change all the stuff. especially the water pump, water jacket etc. i learned my lesson. at lesson i get to whack my engine for 4 years. hahaTime for a fresh start with a new engine then....poison..poison..
Did you check again after a few weeks?I flush 2 time already. Because the ex owner didn't take care of the engine.The 2nd time I open the bottom cap at the radiator let the coolant empty it 1st then fill it with water and run the engine.
And I let the water go out from the top pipe and I keep tembak the water inside to the radiator.
Sounds like mine except mine requires very frequent smacks. Connection not goodI had check. The coolant still are green colour. Not like the 1st time all become Milo Colour. Now car running fine and cool.
Another funny thing.
The temperature gauge always malfunction. So I always smack it. But after few time of punching instead of smack,now thr temperature gauge works perfectly fine. Hahahahhahahaha
Best you remove the top hose and let everything flow out while filling the radiator with engine running, until the water comes out clear then only fit back the hose and add coolant.
But looking at the condition, maybe you need to send to radiator specialist to open up for cleaning.....
You're a real online shopaholicWira update.
Had bought some daun pisang & a universal fog light to fit my mivec bumper.
Distiled water helps but not as much as you thinkthis round going to use drinking water + coolant
radiator only... need to swap engine... "ai meh?" (in hokkien). hehehe....
For the moment, just use plain water. Flush it every few days or weekends, until you are satisfied it's cleanradiator only... need to swap engine... "ai meh?" (in hokkien). hehehe....
