minibeany
598
102
543
this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahaha
you suggest to get a new radiator? if the radiator causing the rust. how many mm? double layer aluminium?
sanekit
Dec 9, 2015
1,616
157
usually after flushing and then add coolant, if there's still rust, it's from the water passage inside the block. u will need to remove water pump, thermostat and water plug at the block side and do chemical flushing to remove all the rust. then radiator send again for service and cleaning. should be able to clear the rust out that way.
alo guys,
need help bro.warnna take off my bug-eye kancil bumper.tried once but still cannot.
let me get this straight.firstly,there's 4 nuts to be taken off from the upper part of the bumper(along the radiator side),then,there's one behind the plate number.then,two more at the wheel arc,right?then,is there any more nuts i'd missed?help guys...thanx
