minibeany
598
102
543
this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahaha
you suggest to get a new radiator? if the radiator causing the rust. how many mm? double layer aluminium?
sanekit
Dec 9, 2015
1,616
157
usually after flushing and then add coolant, if there's still rust, it's from the water passage inside the block. u will need to remove water pump, thermostat and water plug at the block side and do chemical flushing to remove all the rust. then radiator send again for service and cleaning. should be able to clear the rust out that way.
The Marketplace Top Posts
Now mine current tyre is not working very well in wet (about 40-50k used, continental cc6). I planning to change new tyre after a few month, is there any review of your current tires performanxe please comment below.
My budget around 180-250 per pcs. Any suggestion and review for Yokohama Advan fleva, Michelin ps3, Hankook v12, Hankook v2. Any penang or area tires shop recommended.
