Proton wira 1.5GLi need help!!
Oct 12, 2017
Brunei
Hello, anyone know what cause the problem of my car wont start. I’ve change the new fuelpump already, i’ve checked the fuelpump relay already but there no power to the fuelpump..
Tolong lah tolong lah..
alcyon
alcyon
766
142
543
There should be a connector under the back seat, that goes to the fuel pump, disconnect that, and get one person to try and start the car, while you place your multimeter connection on the connectors. See if there's any voltage getting through. Actually is the tank back on the car? The better way is to check if fuel pump is working before re installing tank.
15,323
6,399
Is there crank? Weak or strong crank? Tried changing battery?
