minibeany
598
102
543
this kind of rusting not advisable to use coolant. later become like my car. the water jacket terus burst, bypass pipe burst. coz coolant eats through the rust. hahaha
you suggest to get a new radiator? if the radiator causing the rust. how many mm? double layer aluminium?
sanekit
Dec 9, 2015
1,616
157
usually after flushing and then add coolant, if there's still rust, it's from the water passage inside the block. u will need to remove water pump, thermostat and water plug at the block side and do chemical flushing to remove all the rust. then radiator send again for service and cleaning. should be able to clear the rust out that way.
Hello guys.. Jus wondering whether its makes sense to do an engine swap to an old Fd2 to give it a new lease of life for daily and weekend ride once in a while.
A K24 swap with FD2R gearbox...on hondata, Tein coilvers with ultra racing front tower strut bar and rear sway bar. Bushings replaced and refurbished. Not gonna do those full conversion stuff though...not an R will always never be a FD2R. But jus enough to have some fun once in awhile.
Thanks. Cheers
