top overhaul
yeah, that would be a cheaper alternative.
spend RM1.5k first, to do up the engine and leaks.
the turbo upgrade/repair, is just a tag along.
helps to save some penny amount on the labor.
repair of the turbo, cost like RM1.4k
while buying a new one, AVS TD05 20g, cost RM1.8k..
*sigh.. need to find money*
I notice initially, the understanding was only a top overhaul but based on his quotation, it has become a full overhaul.
he has help me to save cost by repairing the ISC, the clutch, flywheel.
a metal gasket of 2.0mm, is quality.
free ecu wiring do up, my current is a messy, like bee hoon..
Change pistons become full overhaul loh......hhahahhaha:biggrin:
is it?
sorry, I really don't know that's why I seeking your advise.
Its not really changing pistons, its changing of piston rings .
please view again..
You say it is becoming a full overhaul, just missing the pistons loh! Usually a top overhaul almost same work as full overhaul unless you do a De-carbonize job only. To change the rings all got to come out
kurt_629
872
54
johor
yeah, double confirm with him.
it will be a full overhaul, like you mentioned, since its out.
he will charge me the same while doing the full.
actually, I very fearful..
not that I don't trust him..
I am worried, by doing , will I get to see more cans of worms..
*stress*
I go and smoke better..
kurt_629
872
54
johor
may I ask, does overhaul improves FC?
it's kinda ridiculous.. It took me half tank from Ipoh to Cheras, no jam.
1 full tank from Cheras to JB, no jam..
speed, 130-150km..
normal?
drummydrew
471
*stress*
i have been in that uncertain situation before, you have all the rights to doubt him since you are the one on the paying end through all these. i doubt a mechanic can charge a top set OH the same as full OH. based on my own painful experience, better get him to bring you through the procedures that he plans to work on the engine after its taken apart, and price :listen:
on a side note, hijack abit :burnout:
any opinions from sifus in here on the procedure Engine Balancing on engines that are 10years above, after it's being overhauled? will it help restore the engine's performance back to optimum? most importantly, is it necessary? :stupid:
RENESIS VIII
7,063
950
Ipoh
speed, 130-150km..
normal?
Technically, overhaul does improve FC because it cleans away all those excessive carbon deposits inside your engine. It helps your engine to breathe better and operates smoother almost like a new engine. In that sense, it should improve FC isn't it? Compared to an engine with a lot of carbon deposits.
lsm1991
1,469
185
speed, 130-150km..
normal?
erm..... normally if its all spanking new, as with new engines, the fc gets better after the wear in period..... (meaning that it should get slightly better after driving abit)
whether that figure is better than your old figures, really depends on how poorly the engine was before the overhaul.... only you would know.
speed, 130-150km..
normal?
Monitor your mileage, outstation mileage should always be better. If getting low mileage outstation means town driving mileage must be really bad.....:smokin:
You should balance the engine while doing the overhaul. According to my friend who did it, suppose to be smoother and less vibration
kurt_629
872
54
johor
town driving, is bad for sure.
lucky, I only drive this car for few days per month..
basically, it drinks a lot
what is balance engine about?
I thought with the engine mount, it should be quite well balanced?
kurt_629
872
54
johor
ok, after a few month of hard saving.
I finally got RM1.5k which remitted to my mechanic, will be sending the car next Saturday.
bought my own engine oil, shell helix, coolant, gear oil, spark plug & silicon drive shaft cap if need to be replaced.
a kamak td06 18g.
I told him to work within RM1.5k, nothing more as I don't have money for it unless really necessary.
Wish me luck..
RENESIS VIII
7,063
950
Ipoh
a kamak td06 18g.
Wish me luck..
Good luck and hope your engine will come out better than before.
Did your 1.5k include engine oil, gear oil, coolant and all those listed above?
kurt_629
872
54
johor
thanks :proud:
engine oil, gear oil, coolant and all those listed above, is I bought myself, hence excluded from RM1.5k, it should be suffice, provided.. not too many upset..:adore:
RENESIS VIII
7,063
950
Ipoh
thanks :proud:
I guess if so, your mechanic just need to get the top overhaul kit and whatever that needs replacing during overhaul. The rest should be workmanship costs.
Problem is when open up and see things need replacing, cannot leave out. If not, second time open, second time charge.....:smokin:
But usually top overhaul more towards cleaning the carbon, grind the valves....:driver:
RENESIS VIII
7,063
950
Ipoh
Yeah, I understand this part about open up and see things that need replacing. I explain using this when friends are asking me about overhaul.
Cylinder head also need to be skimmed right?
lsm1991
1,469
185
head only skim if its warped/not flat, otherwise xpayah
Like bro. lsm1991 mentioned no need. Skim only if overheated and warped. Simply skim increase the compression later need higher ron....lol
Hi all,
Until today my brake system is still not that powderful. Few weeks ago, i brought my car to check my brakes .. so what they did is .. they change both front and rear brake pump, new brake fluid, clean the inside caliper and replace the tubes. I also change a new brake pad.
Then I found some weird noise when I stop the car .. I can hear this 'tik tik tik' sound. And, when I engage 1st gear got this weird noise too not 'tik tik tik' sound. :(
Any sifus can tell me what is wrong...
