Best tyre for racing?
titipoh
Jul 4, 2012
7
hey guys, anyone know what is the best tyre for racing purpose? anyone these tyres before : Bridgestone Potenza RE-11, Toyo R888 and PSC2? come share your experience! :)
Driver skill leh? If driver is a complete noob then get the grippiest tyre your budget can afford. If you're Ivan/Ian Khong or Kenneth Koh or Karamjit Singh, then even Silverstone tyres will get you podium finish.
Supra_Fanatics
20,673
3,998
RE002? :biggrin:
cheapest tyre...
and learn from there :driver:
Don't la. Dangerous wo if pushed to the limit.
actually its safer....
because the grip limit was so low...
the tyre starts sliding around at lowest and safer speed than those racing compound tyre....
so TS can start learn how to control the car at the safe tyre limit.......
after that switch to sticky slicks and see how much faster and safer he/she was...
*ppl said i'm the original bunta :listen:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
mana fstr :rofl:
i have to agree.
mounting the best tyre wont guarantee faster lap time or podium finish.
its down to well...combination of everything.
cheaper tyre will helps reveal what the chassis is like when grip is gone.how it understeer or oversteer.some fwd will oversteer due to the stiff suspension at the back.
cheap tyre will reveal these at lower speed so it helps the driver learn.imagine if the rear suddenly snap sideways at high speed corner?
not a fun thing as i experience with the neo cps on conti sport contact when i purposey throw it at a corner at high speed.lucky the chassis is well built and makes it easy to recover.
once the driver master the handling and make necessary tweak,upgrade to better rubber and enjoy.
Guys, I wanna ask. When tyres pushed hard, no sound or sound better?
Or its just me being too slow :slug:
i prefer tyre which produces sound when near limit.
some tyre like the cheap sime astar 300 does not produce noise even when it is already loosing grip.
that is not good when the feedback is also vague.
the conti sport contact on the other hnd is a soprano singer.
it luv to sing but that does not mean grip is less.
grip is there..treat it as background music.
on high end tyre...maybe u need more g to squeal it.
---------- Post added at 02:48 PM ---------- 6 hour anti-bump limit - Previous post was at 02:46 PM ----------
come to think abt it,its kinda hard to squeal a rubber a part from doing wheelspin from standstill.
on agressive driving oso hard as we tend to stay within the limit.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
I whacked it hard the other day of my ATR Sport. Squeel halfway gone. Perhaps tyre flex hhahaha
drive slowly brudder, dowan u end up like the evo owner.....:driver:
His should be okay, probably 90whp.....:driver:
---------- Post added at 04:15 PM ---------- 6 hour anti-bump limit - Previous post was at 04:14 PM ----------
Can, got people use ATR Sports for track also.....:smokin:
Hello all, I'm currently using a GSR Turbo with TD05H E3 turbo. Using E-Manage blue for tuning and running at 1.1 boost. I'm using E3 fuel injectors 510cc. Blitz boost controller.
I thougt of upgrading to higher topspeed. Curently I'm getting 210kh/h @ 7,000 rpm on stock GSR gear box. What's all the sifu's advice on this? Should I go for E3 gearbox? Or E1..E2 gearbox? Or just chg final gear ratio and add LSD?
What's the recommended boost? If I boost 1.5 bar, should I change the...
