Best Tyres of 2019 from Tyre Reveiws UK
6UE5t
6,000 RPM
6,756
1,300
Interesting year indeed with the release of the Goodyear F1 SS series and the new Hankook S1 Evo 3. Falken FK510 still seems to be the best value for money though.
minibeany
598
101
543
What is your tyre size?
15 inch. currently using 195/50/R15
wondering if using 55/R15 slightly thicker will be more comfort ride.
FYI, i stay at PJ. Lots of potholes and bumps. I read CC6 is soft and good to cushion the bumps but too many it will puncture the tire because of soft sidewalls. Is that true?
Beyond 20,000 RPM!
29,998
Most use 55R15 for wira. CC6 is entry level, for comfort and durabilty. Not so easy to puncture unless you damage the sidewall, means sidewall getting cut when going into the pothole, or high speed going into the pothole.
Definitely 55R15 will be more comfortable than 50R15
6UE5t
6,000 RPM
6,756
1,300
Better use 195/55/15, more comfortable and more common size. Buy Hankook V12 Evo 2, the best value for money in that size and way much better than that crap CC6, only rm165-170/pc if in Klang Valley.
  • Like
Reactions: minibeany
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
thinking of upsizing my tyre from 225/50-17 to 225/55-17
just not sure if my wheel-arch would fit or not.. :biggrin:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
What was your original tyres, 225/50R17 or something else?
ori is 225/45-17
now on 225/50-17 :biggrin:
thinking oem new forester 225/60-17 but wouldnt fit the wheel arch
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Your model forester much lower, original 225/45R17, better maintain 225/50R17......
thinking of upsizing for overdrive on highways (although the speedo reading will be under-reading too far with 225/55-17) :biggrin:
Hi guys, I'm planning to do 1.3 piston conversion to my 1.6 campro.
The workshop guy said he needs to open the block to check and see if there is any freeplay of the pistons, if so, the block needs to be rebored either 0.5 to 1mm.
Is it safe to rebore block? Or is it even safe to bump the compression of my campro? thanks guys :adore:
Can increase compression without management ma?
