haha sorry bos...might have overlooked his sentence...Never read TS first post.......
No problem, you know me, sure tease you if you miss something....hhahahhahahahaha sorry bos...might have overlooked his sentence...
haha.haha sorry bos...might have overlooked his sentence...
Misaligned will be hard to engage all the time, right? Why only when hot?Ooo ya one more thing, try adjusting your gear lever, might have misaligned.
cos the tapak of the gear lever has bushings rite, if its worn out will effect gear change.Misaligned will be hard to engage all the time, right? Why only when hot?
Yah! then hot or cold also hard to engage mah.....cos the tapak of the gear lever has bushings rite, if its worn out will effect gear change.
could try check it out though.
Then need change gear oil...Try 75w-90 viscosity or add gear oil additives....mine only when engine run for around 10km then very hard to engage gear already.
Before 10km, gear still can engage no problem.
Later update if the problem solved.Then need change gear oil...Try 75w-90 viscosity or add gear oil additives....
