Satria Neo battery flat + cannot manually unlock car
LiLSaInTs
28
Hello guys,
I've this problem that my battery is flat due not starting the car for few weeks. Now there's soft alarm sound and i can't unlock my car even manually. Any solution? Is this because the captor system in satria neo?
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
Hello guys,
try pull the door handle, then twist the key to open.
twist key while handle being pull.
Oct 12, 2009
Hi LiLSaInTs,
I have the same issue. After I changed my battery, I am not able to open my door manually.
I am looking for solution, may I know how you solve your problems?
Thanks.
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
I don't understand why you can't unlock the car with the key?
at first i don't understand it too when a neighbour of mine having the same problem & have to get a mech to open the hood & change the batt. untill now i do not have the answers too:banghead: i wonder if it is stated in the manual or not. i wonder how many of us who buys new car ever read the manual.
Mar 3, 2018
My case is I left my car with the interior lights on. By the time I realized, it was already past 2 days. Can't find any way to manually unlock the car, even the car boot pun tak ada key hole. From the door whenever I tried to unlock, there isn't any sound at all, kosong. Called battery. Com or something they advised me to call my insurance, they will do the unlock, then baru they can come n bring me new battery. D thing is, kereta ni sambungbayar. Faham takk the struggle here! =(
Any other ideas to help me unlock this car?
scoupe
1,087
37
5,148
shah alam
what car is it?
All keyless entry cars have a way to go in when the battery dies. Just google the method online and you'll 99% find your answer
Maybe modded to no manual unlock.....lol
As far as for keyless, the manual key is hidden in the Key Fob. Have to remove and open manually.....
I just noticed the main topic is Satria Neo - but I know the Neo doesn't have keyless entry. So you might be right, aftermarket. If it really is aftermarket then best to go back to the person who installed it for him.
Problem on my engine 4g15
locking sound besause of
-distributor unit
-or underfiring at combustion/etc cycle
The scenario is
-when my car is underpower (cornering or wrong gear ratio) this will happen
Solution
Have cut the spring inside the distributor unit
-The sound disapper
But then after change engine(previously 4g13) to 4g15,the sound came back.
My concern is
Do i need to change the distributor unit or do the port n polish+top overhauled because i want to put powerzone camshaft...
