Underpowered Merz
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
:banghead: Can anyone out there suggest ways to modify an underpowered Merz E-200 model W210 year 1998. Its manual transmission. I can feel its slightly underpowered when at standstill to climb a steep slope especially at traffic lights junction,
All suggestions on modifications, where & cost welcomed!
ixeo
4,788
3,080
KL, Malaysia
Before the jokers rush in and tell you to change K&N air filter, put cold air intake, change exhaust system. I'll tell you don't waste your time. Its not going to be worth anything given the weight of the W210. Curb weight 1.7 tonnes. On paper 134 bhp and 190nM (19.35 kg-M) torque, and over the years some horses died.
Toyota Vios Turbo: Killing Boredom
Here's a dyno of a W210 with the 2.4L V6 Engine, 137bhp and 17.89kg-M torque, compared to 168 bhp and 225nM (22.95kg-M) when new. So dead horses and tranny loss is about ~20%
Using ~20% as tranny loss & dead horses correction, your car would make about 107.2bhp & 15.48kg-M on wheels. Keeping in mind the car is 1.7 tonnes, even at 137 bhp, its a waste of time. To tune your car to 137 bhp is an increase of 27.8%. Natural aspiration tuning to gain 27% is very expensive. And even then, its still slow -- remember, the car is heavy!
For comparison sake
Power to weight ratio (higher is better, more hp per lbs)
Your W210: 0.0283528292
2.4L V6 W210 in the dyno: 0.0362344925
Myvi 1.3L: 0.0319632958
Dyno for Myvi: http://www.strombergpowerbooster.com/ifc/images/myvispecvonwheel.jpg
Proton Gen2 CPS: 0.0405282939
Dyno for Gen2 CPS: http://images.paultan.org/images2/Proton_GEN2_Campro_CPS_Dyno_Chart_Large.jpg
Even IF you successfully modify your 2L to the performance levels of the 2.4L V6 engine, it is still pathetic and waste of time, and the makcik in the Gen2 CPS will have more power from standstill climbing the slope and you'll still look like a snail.
If you want it to be significant to make a difference and not "underpowered". Slap a turbo or supercharger on it, or swap in one of the AMG mills. Otherwise, don't waste time, get the new CGI or CDI Mercedes.. it'll change your perception about power.
D7zul
2,697
848
Shah Alam
no matter what u do to d engine.. ur car will still be heavy..
& heavy car need more power to move..
if it's me, i'd change my car..
:biggrin:
peeche
395
165
Sin City, MY
For comparison sake
on my perception..
previously my dad own a 230e w124.. perhaps the pick up is quite lousy. but it have the grunt at high speed.
then he upgrade to e280 w210. the pick up is hardly comparable to my perdana v6. maybe weight is the main reason.
if i was you. i'll overhaul the engine to can gain back all the lost power. and enjoy the comfort and built quality of this old tank.! :adore:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
swap in 2.3 liter kompressor engine perhaps?
Timeattacker
416
19
Johor Bahru
m.facebook.com
For comparison sake
:love: Indeeds..
before u need to do more further and do sumthing to ur "BABY",spend sometimes digging in and getting more info.before u make ur final decision,as u make wrong move u will b "Re-gret"..
Aiya.. it's a Merc from the generation where they made them indestructable. Plonk in a 2jz and spend all the money on modding the 2jz. Hehehehe.. Probably would be cheaper to buy a new car though.
ixeo
4,788
3,080
KL, Malaysia
on my perception..
no need to overhaul if the engine is healthy...why spend money on it? just enjoy the cruise and comfort in it.
Sounds like abomination.. tasty tasty abomination.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
I'm no merc expert but since the 2.3l kompressor came from the same family rite? the "E230 Kompressor" model. from spec it look healthy @ 197 PS (145 kW; 194 hp) and 280 N·m (207 lb·ft ( found here ) and since came within the same family should be PnP... :hmmmm:
Although it's performance is not as high as the venerable 2JZ-GTE (even 1JZ-GTE), but 280 N·m sounds about right... my 2 sen la
Forgive my geekiness :adore:
Yep agree with papagiones, swap with a latter kompressor engine...just find a reliable mechanic.
The Marketplace Top Posts
bros,
considering of converting my 4G13P to GSR...
however, i dont know of runners to do the following with JPJ..
anyone has done it before can advice and recommend??
i understand that's it'll cost a large amount of "kopi" money...around 1.3K+ is it true??
thanks ahead..
