EVo 3 4G63 advise ?
huakenny
LB Performance
9,126
240
Kota Kinabalu
this 4g63t is from evo3
current mods is only ARC big intercooler, mines ecu, knn 6inch air filter. fujitsubo catback only. stock boost.
this is my bro car and so asking sifus here :p
search previous threads bout 4g63 but all monster mods, not so applicable to me
he planning rebuilt and to put in :
1)1.8mm cometic head gasket
2)iridium spark plug
3)aftermarket plug cable(if necessary?)
4) walbro 255lph intank fuel pump
5) boost meter
6)boost controller
turbo seems got problem, wanna sent to rebuilt. to rebuilt back the same spec or upgrade to 20g is better?
this car only wanna daily drive and sometimes boost here boost there only...not for race
if the current mines ecu is good enuf, guess he wont install piggyback system at the moment.
guest
346
20
Kota Kinabalu
cool la bro...once done the post here k..where do your brother sets all the things?my car now when start engine ca hear the knok knok knok knok sound worr...i tot it was tapped sound but tapped got sound also near head tap tap tap tap...this i think like near the injector..around there la...haiya....
huakenny
LB Performance
9,126
240
Kota Kinabalu
Paiseh....I'm d one to do.....juz tat I more familiar wit newer gen vehicles....so for tis old machine,I try to seek different opinion from members here.......
Veloc
3,234
991
Sabah
Done dy race with your gtr k? HAha... See can keep up or not! Please keep us updated. so eager to know how is it!
thilaksharma
From Facebook
Sep 21, 2011
60
19
508
www.facebook.com
5) boost meter
6)boost controller
If I was you , these is what I would do, boost the car up a little to get a nicer performance
1)1.8mm cometic head gasket - yes needed , the E3 has a high compression engine
2)iridium spark plug - dont need, even 700hp cars still use Copper plugs
3)aftermarket plug cable(if necessary?) - not needed if yours is doing good
4) walbro 255lph intank fuel pump - yes needed , make sure original
5) boost meter - of cos u got already
6)boost controller - a normal Tee boost should be good
As for the turbo, you dont have to change to 20g yet, you are still at 16g so you might as well service it and fit in a piggyback to tune it, maybe boost 1.4-1.5bar , the 20g will require much much more hardware requirements
hehe modding turbo has many step
next you would want
1. SS intercooler pipes
2. a nice BOV that holds boost
3. Clutch that can hold the power
4. Nice piggy or standalone
5. injectors
6. and the list will go on n on n on :P
huakenny
LB Performance
9,126
240
Kota Kinabalu
nola bro....i dun think this evo can chase my gtr.......lolz
---------- Post added at 10:53 AM ---------- 6 hour anti-bump limit - Previous post was at 10:48 AM ----------
Thanks thilaksharma,
1)1.8mm cometic head gasket - yes needed , the E3 has a high compression engine WILL DO
2)iridium spark plug - dont need, even 700hp cars still use Copper plugs WILL DO AS PLUGS GONE
3)aftermarket plug cable(if necessary?) - not needed if yours is doing good OK..HOLD 1ST
4) walbro 255lph intank fuel pump - yes needed , make sure original YES ORI FOR SURE
5) boost meter - of cos u got already WILL INSTALL..LOLZ
6)boost controller - a normal Tee boost should be good YES, TURBOSMART BOOST TEE ONLY
As for the turbo, you dont have to change to 20g yet, you are still at 16g so you might as well service it and fit in a piggyback to tune it, maybe boost 1.4-1.5bar , the 20g will require much much more hardware requirements.... OK..16G THEN
next you would want
1. SS intercooler pipes GOT EDI SINCE WITH ARC BIG IC
2. a nice BOV that holds boost YES..WILL FIND ONE
3. Clutch that can hold the power LATER THIS ONE,LAZY DOWN ENGINE YET
4. Nice piggy or standalone NOW WITH MINES ECU,TEST 1ST
5. injectors WILL CHECK AFR 1ST
btw, i will boost around 1.2bar 1st, up only later if no problems
thilaksharma
From Facebook
Sep 21, 2011
60
19
508
www.facebook.com
next you would want
2. dnt get the iridium plugs, too many imitations and expensive, not worth a cent also, get evo3 Oem plugs from the motorcycle shop, BPR7ES
5. I broke my first E3 within days , because i dint have boost meter hehehe :P too syiok without knowing boost level
6. on the right track :)
1. Dont mind me asking whts the size of the ARC u have n how much u got it, i am looking head to tail for ARC i/c but all small small ones only found
2. Greddy Type-S and RS a very good choice
4,5 Good idea, AFR :)
huakenny
LB Performance
9,126
240
Kota Kinabalu
IRIDIUM ori coz im selling...lolz
the ARC is for GTR33 actually.....
the car is lying in store too long...its time to wake it up my bro said:smokin:
hi...just purchased a momo gear knob (golf ball design) and trying to fit onto kancil gear. original kancil knob is screw on. when i bought it first n tried 2 fit it, used the supplied rubber adapter and then put the knob on top, some of the grooves on the inside of the knob were a bit worn out and couldnt screw properly. so took it back 2 brothers and after going through 2 or 3 knobs, 1 was not too bad. i decided to ask them to install it 4 me. the guy did it and it was alright, but if try...
