hi...just purchased a momo gear knob (golf ball design) and trying to fit onto kancil gear. original kancil knob is screw on. when i bought it first n tried 2 fit it, used the supplied rubber adapter and then put the knob on top, some of the grooves on the inside of the knob were a bit worn out and couldnt screw properly. so took it back 2 brothers and after going through 2 or 3 knobs, 1 was not too bad. i decided to ask them to install it 4 me. the guy did it and it was alright, but if try to turn it can turn a bit, then 2day i went to another accessory shop and asked them if they can do anything 2 tighten it and they screwed up the whole thing, took out, removed the rubber, tried using black wire tape...blah blah, then the constant removal of the screws caused the grooves to wear out again, now im back using the stock knob and gonna go n change it again at brothers. anyone has any idea on how to fix the knob securely onto the stick without it having to move??
thanks.
thanks.
