S.O.S - Satria Neo (A) 'engine failure'
Dec 4, 2013
Johor Bahru
Hi all, my Satria Neo 2006 also have engine overheat problem. Sorry I don't have a screenshot of the temperature. I was at the Causeway, engine idling, when suddenly the engine failure. The engine temp shot up to around 120 deg cel. There was also the red oil and battery icons on the display. I switch off the engine and restart the engine. I could travel a very short distance before engine failure again. Then I switch off the engine and waited a few minutes. The engine temp drop and I could drive normally again.
Does anyone have this similar problem? What could be the cause of the problem and the solutions?
Please help thanks a lot.
Rainer
Rainer
Did you check to see if you have water in your radiator?
neo83
318
9
518
Johor Bahru
Rainer
don't play2 bro..
refer at my last post..
http://www.zerotohundred.com/newforums/satria-neo-forums/437629-skim-head.html
YYC
1,833
939
Add to the above, water pump failure. But this one hard to check without dismantling.
Is there bad effect for making short exhaust system?. Means, the exhaust system are:
4-2-1 extractor --> "nenas" -> bullet straight flow --> straight flow muffler ( length: from engine till under back seat)
Need advise for this exhaust system...:adore::adore::adore::adore:
